				lightpasses too bright?
				Posted: Tue Feb 10, 2015 2:09 pm
				by whersmy
				I think I`m doing something wrong, but I can`t get two passes to combine properly like it should according to the how-to:
http://render.otoy.com/forum/viewtopic.php?f=51&t=44350
in PS i have:
1 ambient pass
1 lightpass
when adding linear dodge the image becomes too bright, i need to change the fill value for correction?
i saved out 16-bit pngs and kernel with PT
				Re: lightpasses too bright?
				Posted: Tue Feb 10, 2015 8:19 pm
				by stratified
What are your imager settings? You need to make sure you are working in linear color space. Can you try to set your gamma to 1 and the response to Linear/off? This should add up in post (you need to gamma correct the image in Photoshop afterwards because otherwise it will look too dark.).
cheers,
Thomas
				Posted: Tue Feb 10, 2015 10:30 pm
				by whersmy
				changed the gamma to 1 in standalone + linear response, it get`s better, but it`s too bright when combining them in ps (cs4)
do i need to change exposure to 2.2 in standalone?
				Posted: Tue Feb 10, 2015 10:43 pm
				by prodviz
				Use 'Screen' blending mode on 16bit images. Use 'Add' on 32bit.
				Posted: Tue Feb 10, 2015 11:00 pm
				by whersmy
				yep that does the trick! thanks!
				Posted: Wed Feb 11, 2015 11:16 am
				by whersmy
				hi stratified,
Does changing the opacity in post of an extra lightpass equal more or less physically correct changing the power of a lightsource?
i`ve been looking into this and it kind of works to tweak / balance light, im just not sure if it`s physically correct
cheers
				Posted: Wed Feb 11, 2015 7:48 pm
				by stratified
				whersmy wrote:hi stratified,
cheers
The formula is
total light = C1 * L1 + C2 * L2 + ... + Csun * Lsun + Cambient * Lambient. Tweaking
Ci modifies the power of the light. But I don't think you need to change the opacity of the layer (maybe I'm wrong). I will have to try later with PS but I tried this experiment in Blender and there I had to use the gain on the color correction node.
cheers,
Thomas
