OctaneRender™ for Blender 2.21.1 - 7.1 Win [OBSOLETE]
Posted: Tue Feb 10, 2015 3:14 am
				OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
Blender Octane Edition - 7.1 (2.73 (59.1MB autoinstaller file)
Octane Server - 2.21.1 - 7.1 (10.5MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.21.1 - 7.1 (9.0MB autoinstaller file)
- Merged with Blender 2.73.
- Switched to 2.21.1 engine.
- Mute function for Octane nodes is implemented (select node, press "M").
- Now you can choose in render settings what for HDR you need to render - tonemapped or not.
- Added Octane render layers. You can set the layer ID in the mesh's Octane properties and enable layers in Octane Layers properties. Global mesh is always on layer "1".
- Added new passes: "Shadows", "Black shadows", "Colored shadows", "Layer reflections", "Render layer ID", "Render layer mask".
- Added Octane Noise texture.
- Added "Affect alpha" attribute to specular material.
- Removed "Keep environment" attribute from kernels.
- Removed "Start samples" attribute from passes settings.
- Fixed the camera rotation bug.
- Fixed imager presets bug.
- Minor fixes...
