Page 1 of 2
My comp turns off. Overheating?
Posted: Tue Jan 20, 2015 10:07 pm
by PAQUITO
It just happened when rendering with Octane. After about 30 mins. of rendering it just turns off. No warnings, just... boom, you´re off.
After a couple fo minutes it turns on again to normal. Anyone can bring some light about this? I´m really pissed with this, specially in the summer, that´s why I think about overheating.
Re: My comp turns off. Overheating?
Posted: Tue Jan 20, 2015 10:23 pm
by glimpse
Hi, Paquito.
My guess it might be PSU, ..but let's see:
Dowload & install GPUZ,
open a GPUZ window per GPU & activate log files to write all sensors of every GPU (should have separate files for every GPU)
Now work like normal & attach these log files after crash =).. - we'll see if crashes are caused by GPUs =)
Posted: Tue Jan 20, 2015 11:51 pm
by PAQUITO
How do I set it to have a long for each card? I have a 690 and there appears two cards with sli enabled. Should I make something special or just leave it as it is?
Posted: Tue Jan 20, 2015 11:54 pm
by face_off
You can probably just monitor the temperature of one of the 690's (since they are the same card they will have the same temp). Also, my understanding is that you need to DISABLE SLI.
Posted: Wed Jan 21, 2015 12:01 am
by PAQUITO
Sorry, I must disable SLI to work with octane or to make the logs?
Posted: Wed Jan 21, 2015 12:05 am
by whersmy
Also get MSI afterburner to measure gpu temps. You can also monitor if a card has power spikes bumps that are caused by the psu when rendering.
For Octane disable SLI
Posted: Wed Jan 21, 2015 12:51 am
by PAQUITO
Could you expand that a little? Why you should disable SLI for Octane? Should I disable also for gaming? What is the difference?
Posted: Wed Jan 21, 2015 1:42 am
by face_off
Otoy recommend disabling SLI for rendering (http://render.otoy.com/faqs.php). A number of users have reported that enabling SLI has caused crashes.
Posted: Wed Jan 21, 2015 3:35 pm
by PAQUITO
Ok, I see. By now I disabled SLI and will continue working under gpuz monitoring so I can have some info if the problem appears again. Thanks.
Posted: Wed Jan 21, 2015 4:22 pm
by whersmy
cool, let us know!
