OctaneRender™ for Blender 2.15 - 7.0 Linux [OBSOLETE]
Posted: Mon Dec 15, 2014 3:33 am
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v7.0 Linux (102MB autoinstaller file)
- Switched to 2.15 engine.
- Octane render passes are implemented.
- New "Highlight compression" pin in camera imager node.
- New "Path term. power", "Coherent ratio", "Static noise", "Max speed" pins in kernel nodes.
- New "Roughness" pin in Diffuse material node.
- New "Turbulence", "Invert" and "Gamma" pins in Turbulence texture node.
- New "Hue", "Saturation" and "Contrast" pins in Color Correct texture node.
- New "Cast illumination" and "Surface brightness" pins in emission nodes.
- New "Polygon Side" texture.
- "Distribution" pin of emission nodes is now "Emission pattern"
- The emission sampling rate can now be set to "0".
- Removed obsolete "Brightness scale" and "Black level" pins from Color Correct texture node.
- Removed obsolete "RRprob" pin from kernel nodes.
- Removed obsolete "Fstop" and "ISO" pins from the camera imager node.
- Exposure of the camera imager now is scaled differently, so be prepared to that when opening the old scenes in this version.
- Minor fixes...
Installation:
# OctaneServer &DOWNLOAD
