Page 1 of 6
OctaneRender™ for Blender 2.15 - 7.0 Win [OBSOLETE]
Posted: Mon Dec 15, 2014 3:33 am
by JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Switched to 2.15 engine.
  • Octane render passes are implemented.
  • New "Highlight compression" pin in camera imager node.
  • New "Path term. power", "Coherent ratio", "Static noise", "Max speed" pins in kernel nodes.
  • New "Roughness" pin in Diffuse material node.
  • New "Turbulence", "Invert" and "Gamma" pins in Turbulence texture node.
  • New "Hue", "Saturation" and "Contrast" pins in Color Correct texture node.
  • New "Cast illumination" and "Surface brightness" pins in emission nodes.
  • New "Polygon Side" texture.
  • "Distribution" pin of emission nodes is now "Emission pattern"
  • The emission sampling rate can now be set to "0".
  • Removed obsolete "Brightness scale" and "Black level" pins from Color Correct texture node.
  • Removed obsolete "RRprob" pin from kernel nodes.
  • Removed obsolete "Fstop" and "ISO" pins from the camera imager node.
  • Exposure of the camera imager now is scaled differently, so be prepared to that when opening the old scenes in this version.
  • Minor fixes...
Blender Octane Edition - 7.0 (2.72) (57.9MB autoinstaller file)
Octane Server - 2.15 - 7.0 (10.3MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.15 - 7.0 (9.5MB autoinstaller file)
Re: OctaneRender™ for Blender 2.15 - 7.0 Win [TEST]
Posted: Mon Dec 15, 2014 6:31 am
by simdal
yesssss! :D
thanks JimStar
The first test was very positive. No problems discovered. now I try render passes. ;-)
Posted: Mon Dec 15, 2014 7:52 am
by eklein
Thank you for this release.
A couple of issues I notice from previous release.
1. The camera autofocus does not work unless it is set to an object.
2. With a few interior scenes I tested both HDR and emitters seem to be 30% brighter.
Eric
Posted: Mon Dec 15, 2014 8:10 am
by kubicki3d
Thank you JimStar!!! That's a really nice list of new features!
Posted: Mon Dec 15, 2014 3:20 pm
by rz3x
Oh well. My delighted with the new version will be more moderate. More precisely they will not be at all. To test scene I created a lot of glass, glare and bloom to notice the difference in lighting. Noticed. Picture 1.15 version much brighter. And if it was a difficult scene sunset I worked a year? Generally, it is blasphemy - to adapt the rendering so that the picture in all project changes, people can not sleep for hours diaphragm exposed, and they bang and all work is lost. It is not correct.
Now to the "rapture." The new version of Render longer (!) I do not believe it - rendered the twice rearranged version, but the result was repeated.
v 2.06: 3min 10sec:
v 1.15: 4min 02sec:
I am extremely dissatisfied with the fact that the picture became brighter. I thought of the dusty evening, and the new version was a nuclear fungus. Yes, I spent half a second is twisting the camera settings. But the fact that these efforts are offset by the new version is wrong. And even more so for a paid product.
Posted: Mon Dec 15, 2014 5:51 pm
by Inciner
Awww, thank you for this plugin!
You are sooo awesome!!
Posted: Mon Dec 15, 2014 7:10 pm
by Stelios20
I am trying to render and it stops at "Waiting for image...".
I checked the console and there arent any errors.
This happens to every scene. Also when I try to activate my license Octane server crashes.
I have reinstalled twice...
What am I doing wrong?
Posted: Mon Dec 15, 2014 7:25 pm
by JimStar
Stelios20
One of the reasons may be: when using F12 render, you need to enable the pass checkbox if the pass other than "Combined" is chosen as current.
Posted: Mon Dec 15, 2014 7:39 pm
by Stelios20
Thank you for responding!
Even if I use rendered viewport it stops at "Waiting for image..." and the screen is black...
As for the pass checkbox, I dont really know where it is :?
Also the material preview is not working.
Posted: Mon Dec 15, 2014 8:20 pm
by JimStar
Stelios20
Are you sure you have the actual NVidia drivers installed?
