Converting Lights?
Posted: Tue Dec 09, 2014 6:50 pm
by ArtistX1
Is there an easy way to convert poser and/or Carrara lights to Octane lights, or is it a case of we have to use planes and other objects set to use black body emission as the way to go?
Re: Converting Lights?
Posted: Tue Dec 09, 2014 11:43 pm
by PhilW
Yes, you need to substitute the lights with emitter planes or other objects. I think that Sighman considered some sort of automatic substitution, but an object's brightness is a combination of the emitter shader settings and also the size, leading to a lot of complications. Plus you can often use less lights in Octane than an equivalent Poser or DS scene (or indeed Carrara) as you are not having to correct for non-physically correct lights and render settings.
