PC swapped 2xTitansB for 3x780Ti & tweaking
Posted: Thu Oct 23, 2014 4:14 pm
Hi Guys,
for those who are interested in AC system and Benchmark with finetuning GPU.
I did not want to post this in the Bencmark thread, because it is more about the finetuning.
I played with the GPU settings before, just to learn a bit, but now I had to play with the settings to get the system work, because the temps were getting to high.
To start with I would like to ask you pro guys this:
What can I do with the 'GPU CLOCK OFFSET' and 'MEM CLOCK OFFSET'?
Now I just tweaked the 'Power target' and linked 'temp target'
I looked up the old Benchmark with OR (release 1.20) to compare.
This sytem had one gtx275 for the monitor and 2 Titans Black to render.
The result was:
2x Titans Black: 15.03 Ms/sec
2x Titans + gtx275: 15.79 Ms/sec (turned monitorcard on as well)
The machine with 2 Titans are swapped for 3x 780Ti.
with temp targets on 82 degrees
This is the result;
1x 780Ti n01: 8.23 Ms/sec, 81-(41)-(30) degrees
1x 780Ti n02: 8.12 Ms/sec, (38)-83-(30) degrees
1x 780Ti n03: 8.15 Ms/sec, (43)-(38)-75 degrees
3x 780Ti:
(fanspeed 100% and temps were still rising)
then I noticed that PC on the backside had only about 20cm space for airflow! oops.
I hope there is a auto killswitch to protect the GPu from overheating? must be.. but probably a little higher then 90 degrees?
Anyway...I killed the test, rotated my PC a little that the space behind the PC was becoming a meter.
Now the result is
3x 780Ti: 22.29 Ms/sec, 92-96-76 degrees
I noticed the second gpu clock was dropping and rising very quickly.. I guess that is the auto killswitch beause of too high temps
I probably have to conlcude that the PC is not having enough aircooling to run 3 780's
So, I added a fan (I use in summer to survive in my workspace with GPU rendering and sun shining outside
I directed the 40cm diameter fan on the side and back of PC and starrt rendering again to see what happens this time:
the second GPu is getting the hottest and after a while it is also hitting the 96 degrees
So, now I kicked out the fan again (I'll keep it just to cool myself in summer
and I played with the power targets the GPU and I got this result after finetuning
3x 780Ti: 20.40 Ms/sec, 83-88-70 degrees
n01: 57% (849-692mhz, 83 degrees, manual set fanspeed 100%)
n02: 57% (849-692mhz, 88 degrees, manual set fanspeed 100%)
n03: 100% (1124mhz, 70 degrees, auto fanspeed 75%)
I have to say that the renderspeed drop down (by setting power target from 100% to 57% on two GPU's)
is not that big as I would expect: from 22.29 to 20.40 Ms/sec.
but adding the GPU seperately means a dropdown of almost 18% (8.23+8.12+8.15=24.50, to 20.40 Ms/sec)
and that is because not having an optimal aircooling.
(I had to remove one fan (bottom) because the new power unit was larger
Maybe I will try and install the removed fan on the front side.
I got another question:
How can I check to be sure which GPU is the one I use for my monitor?
The confusing thing is that in Octane Render the GPU 1,2 and 3 are the reversed shown in the EVGA Precision X (I use for tweaking).
In the photo you can see the three GPU's and the top one I am using for my monitor.
The bottom one is near the Power unit, but my guess is that that is the one with the lowest temps, because the right fan on the GPU has the most space to breath.
Am I correct?
Greetz,
The result was:
This is the result;
3x 780Ti:
Now the result is
Am I correct?
Greetz,
