Page 1 of 3
xparticles motion blur
Posted: Wed Oct 22, 2014 8:11 am
by jagger
How??
Re: xparticles motion blur
Posted: Wed Oct 22, 2014 1:12 pm
by aoktar
Here
Posted: Wed Apr 22, 2015 7:05 pm
by Janmansilver
Hi, I can't seem to get x-particles motion blur to work in the newest stable release? Other objects blur fine.
Posted: Wed Apr 22, 2015 7:35 pm
by aoktar
Janmansilver wrote:Hi, I can't seem to get x-particles motion blur to work in the newest stable release? Other objects blur fine.
could you tested the attached scene?
Posted: Wed Apr 22, 2015 8:22 pm
by ChrisVis
Hi aoktar,
I tested the attached scene with Xparticles 3 and motion blur works. EDIT: with C4D octane 2.22.2 test3.
However, the cam in your scene was not setup right, because I think you made it before you made some changes to the camera tag.
The good old shutter alignment was set to nothing, so I selected "before". Also there was set a timeshift of 25, set back to 0 and voila, motion blur is there.
Cya,
ChrisVis
Posted: Wed Apr 22, 2015 8:26 pm
by aoktar
ChrisVis wrote:Hi aoktar,
Cya,
ChrisVis
Right, but it's not a mistake. I see this problem on old scenes. Propably this is some broken m.blur attributes(time shift, etc..) between old-new versions. I'll investigate the reason.
Posted: Wed Apr 22, 2015 8:40 pm
by Janmansilver
Hi yes I also tested the scene posted here - the particles simply disappear when activating motion blur in the Octane camera tag.
This is what happens when i open the file
This is the render when not touching any settings
I then turned on the tag, and the render goes dark / the particles disappear
Caching did not help
Tried switching between transform and point - still no particles
Update: Hi sorry didn't see that you've already responded, thanks for so quick support, I'm running X-Particles 2.5 - maybe this could be an issue? I will try the settings suggested above then and will let you now at once. :-)
Posted: Wed Apr 22, 2015 8:56 pm
by Janmansilver
Hi just tested with the suggested settings, but no luck here with X-Particles 2.5 and OctaneRender version 2.16.
Posted: Wed Apr 22, 2015 9:05 pm
by aoktar
following setting are wrong
try:
time shift=0
align. = before
enable particle engine
Posted: Wed Apr 22, 2015 9:33 pm
by Janmansilver
Hi :-) I tested with the exact same settings as suggested and still no particles. I've also tested with the latest beta (Octane-for-C4D-2.22.2-test3) and still no particles.
Maybe it's an issue with X-particles 2.5? I'm runnnings with a GTX 980.
