Page 1 of 2
Clear plastic cap distorts the metallic effect underneath...
Posted: Sun Oct 19, 2014 4:45 pm
by GraemeH
Hi Paul
I have a clear cap with thickness that is sitting over a metallic spray pump top.
It's affecting the metallic effect quite differently than other areas not covered by the plastic. Would you have any recos on how to handle this?
I was using path tracing and pmc @ 4000 but each has a different result, not the one I'm looking for.
Re: Clear plastic cap distorts the metallic effect underneath...
Posted: Sun Oct 19, 2014 6:41 pm
by whersmy
can u post a screen?
are the outer faces of the cap and pump tangent to each other?
rayepsilon setting might help
Posted: Sun Oct 19, 2014 10:01 pm
by GraemeH
Hi whersmy
Thanks for replying. See attached image.
Posted: Mon Oct 20, 2014 2:04 am
by face_off
Try to lowest possible ray epsilon (0.00001?).
Posted: Mon Oct 20, 2014 4:00 am
by GraemeH
Thanks Paul. I did reduce the Ray Epsilon to 0.00001 but didn't see much of a difference. I then proceeded to change the Reflection setting of the clear plastic lid from 0.8 to 0.2. Also, not sure if this helped but changed the index from 1.4 to 1.2. Looks like one of those changes worked to get closer to what I was trying to achieve but have to do some more testing at different angles.
Posted: Mon Oct 20, 2014 6:19 am
by whersmy
are you using gamma 2/2.2? what camera are you using? i think that is key here
Perhaps the gamma of the hdr should be a bit higher
Posted: Mon Oct 20, 2014 12:41 pm
by GraemeH
I'll have to check those things later today. Not quite sure as I'm still learning my way around Octane. Hopefully the game can help as I don't really want to sacrifice the shape and detail of the plastic lid ( which I think I'm doing)
Appreciate your help and will let you know results once I do some more tests
Posted: Mon Oct 20, 2014 12:43 pm
by GraemeH
That's "gamma" not "game"
Posted: Mon Oct 20, 2014 10:56 pm
by rrbarb
What is your refraction set to on the modo material.
Posted: Tue Oct 21, 2014 5:44 pm
by GraemeH
Hello rrbarb, this material is from the octane library. I loaded in one of the clear plastic materials and added above the MODO material, so it would take precedence.
As for the gamma, it didn't really help that much.
I'll keep at it.
Thanks. Hope to have some new shots with solutions.
