8 or 8.5?
Posted: Fri Oct 10, 2014 12:35 am
by gold
Ok, I bought.
Should I use it on 8 or 8.5 ? Or will it run on both at same time?
thanks!
Re: 8 or 8.5?
Posted: Fri Oct 10, 2014 2:30 am
by Tugpsx
Works well on both
Re: 8 or 8.5?
Posted: Fri Oct 10, 2014 4:56 am
by Sighman
gold wrote:Ok, I bought.
thanks!
The installer will only let you install on one but you can simply copy the files over to the other.
Re: 8 or 8.5?
Posted: Fri Oct 10, 2014 6:04 am
by gold
ok great,
Sounds like I should install both, and get re-acquainted that way. { No carrara is on my machine
current, unfortunately. }
thanks
Re: 8 or 8.5?
Posted: Tue Oct 14, 2014 2:37 pm
by ArtistX1
I would say it depends on what you are going to use Carrara for, if you plan to use Genesis then yes you will need the buggy 8.5, for anything else 8.1 should do fine
Re: 8 or 8.5?
Posted: Sat Oct 18, 2014 1:10 am
by gold
Thank you.
I have both installed. I mainly use V4, although I bought 8.5, mainly for the genesis models.
Hopefully version 9 will address bugs. Would it be cynical, to wonder, if version 9 will be
released at the launch of Genesis 3? To support that new figure?
Re: 8 or 8.5?
Posted: Tue Oct 21, 2014 12:16 am
by ArtistX1
With the way daz has treated everyone who has asked about C9 and the lack of information coming from Daz I would have to say "Yes it would be cynical" that they release C9 in time for Genesis 3, if they release a new Carrara at all
