Page 1 of 2
Full motion blur on everything w/o tags
Posted: Mon Sep 15, 2014 2:52 pm
by winkelmm
Hey all,
Just wondering if there is a way to turn on full motion blur on everything without having to add an object tag to each object in the scene? Is this possible?
Mike (beeple)
Re: Full motion blur on everything w/o tags
Posted: Mon Sep 15, 2014 3:10 pm
by aoktar
i think that you are meaning to get transform+vertex motionblur on objects. right? Object motion blur requires a "transform node" for each objects. Transform node provides PSR for defining the transform values of objects.
if you don't put a objecttag, so you can't get transform motion blur. These objects will be exported to a single mesh. this is very similar to connect meshes.
ATM, we don't have a auto method to do this for you. Also I don't advice to activate vertex mblur option for unnecessary objects. Just a info.
Posted: Mon Sep 15, 2014 3:15 pm
by SephirothNP
I may be speaking out of turn here, but putting everything (in a very simple scene) under a null, and then applying the Octane object tag to the null solved it for me.
Posted: Mon Sep 15, 2014 3:18 pm
by aoktar
yes sure! A objecttag will affect all childs
Posted: Mon Sep 15, 2014 3:22 pm
by winkelmm
Aye, yeah i thought of that but just wanted to make sure i wasn't missing some setting... thanks much!! :)
Posted: Mon Sep 15, 2014 8:27 pm
by winkelmm
One other issue maybe you could look at... not sure if it's a bug or not.
I'm trying to use motion blur with a symmetry object but it seems to screw up the motion blur... You can see on the left 'smasher thing' when it comes down (around frame 27), it looks a bit messed up. Any way around this besides not using symmetry?
Thanks much in advance!! :)
tanks,
m.
Posted: Mon Sep 15, 2014 8:32 pm
by aoktar
winkelmm wrote:One other issue maybe you could look at... not sure if it's a bug or not.
tanks,
m.
no need to check your file. There is a bug which comes from c4d. Symetry objects cannot give correct keys throught past keyframe calculations. This seems fixed on R16.
Posted: Mon Sep 15, 2014 8:46 pm
by winkelmm
awesomes. you da man sir!!!! :)
tanks,
m.
Posted: Mon Sep 15, 2014 8:55 pm
by winkelmm
wait, does Octane work with R16 yet? :)
Posted: Mon Sep 15, 2014 8:59 pm
by aoktar
winkelmm wrote:wait, does Octane work with R16 yet? :)
R15 version can work on C4D-R16
