Page 1 of 2
Animated texture issues
Posted: Fri Sep 05, 2014 12:11 pm
by anti86
Hi guys!
I am unable to use a image sequence as texture in octane render.
Does anyone have the same issue and if so, how can i get it to work?
Thank you!
Re: Animated texture issues
Posted: Fri Sep 05, 2014 12:14 pm
by aoktar
Version?
what happens when you try the imagesequence.c4d from samples package?
Posted: Fri Sep 05, 2014 12:39 pm
by anti86
it works when i render the sample file, but when i make a new glossy texture, add a octane imageTexture, select the first frame of a sequence and then under animation insert the start and endframe and the frame rate, it renders everything out as a grey material...
Posted: Fri Sep 05, 2014 12:50 pm
by aoktar
you have to set start/end ranges manually. I'm checking everything is well. Where is your images? under project path or you set that as fullpath of images?
Posted: Sat Oct 04, 2014 2:27 am
by Druzic
I'm having the same problem (ver2.05.0 rc1). The example works fine, but even when I edit a copy of the example(imagesequence.c4d file) to load a different .jpg sequence the new texture doesn't render at all.
Is there some trick to loading the images I'm missing?
Posted: Sat Oct 04, 2014 5:43 am
by Fluffy
Tested in 2.10.0 here with a new scene and my own JPEG sequence and everything rendered properly.
Posted: Mon Nov 24, 2014 1:43 pm
by Monguilhott
I am having the same issue here. I downloaded a scene from the forum (emistex.zip) which contains an animated texture.
I only change the animated texture that is very similar to the sample project and get a grey box!
Is that a bug?
Octane 2.12.2
Posted: Mon Nov 24, 2014 2:24 pm
by aoktar
are you sure your image in under project path? check console output for a file error message
Posted: Mon Nov 24, 2014 2:48 pm
by Monguilhott
Yes, its in the project path. Where is the console output? Is the help/show octane log? Sorry beginner question.
Posted: Mon Nov 24, 2014 3:29 pm
by aoktar
can you try this on diffuse channel? lets see what's happening
