OctaneRender™ for Blender 1.55 - 5.0 Win [OBSOLETE]
Posted: Fri Sep 05, 2014 5:26 am
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
Blender Octane Edition - 5.0 (2.71.5) (64.5MB autoinstaller file)
Octane Server - 1.55 - 5.0 (8.2MB autoinstaller file)
DEMO is now available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 1.55 - 5.0 (7.0MB autoinstaller file)
- Merged with new 2.71.5 Blender.
- Full code refactor and optimisations, prepared to move to v2. A lot of minor bug fixes.
- New transform nodes added. Blender has no "enumeration" subtype for integer pins, so "Rotation order" does not have the user-friendly enumerations combobox - just integer value. It's not the plugin's problem, push on Blender developers about it.
- New Info kernel attributes added.
- Improved working with hi-poly scenes. You should understand that you need really a lot of memory to render hi-poly scenes in Octane and especially in Blender plugin - due to this client-server configuration forced by GPL. E.g. if your Blender scene takes 3GB of memory - the translation to Octane format takes additonal 3GB for Octane data structures, the server receives this data into its own 3GB buffer (this is already 9GB needed in total), and after that - the Octane engine itself will need a lot of additional memory to evaluate BVH for all this geometry... Say thanks to GPL...
- Improved error-messages feedback from OctaneServer to Blender console.
