Page 1 of 2
From c4d to octane standalone
Posted: Thu Aug 14, 2014 11:43 am
by Yan
Hi there!
Another question regarding the export from c4d to octane standalone.
I have tried several times to export from c4 to octane using both the edit in standalone and save ocs, but when octane opens, there is nothing imported....
I've also tried to open the exported ocs with octane standalone and there is still nothing :(
Screenshots here:
https://www.dropbox.com/s/u23yoe7mbg3hx ... .39.38.png
https://www.dropbox.com/s/ja4zi502fjaeg ... .40.07.png
Re: From c4d to octane standalone
Posted: Thu Aug 14, 2014 10:34 pm
by FooZe
Moved to C4D plugin forum.
Posted: Fri Aug 15, 2014 7:40 am
by aoktar
Mac or Windows? have you set standalone exe? it will work after sending the scene to live viewer
Posted: Fri Aug 15, 2014 7:46 pm
by Yan
Windows.
First the software asked for the .exe, than I set it like this: C:\Program Files\OTOY\OctaneRender 2.04\octane.exe
But as I told you even If I save the scene as ocs and open it in octane standalone it shows a blank document.
The c4d plugin is working 100%...just the edit in standalone and save as ocs(the file is saved but is blank) are not working.
Posted: Sat Aug 16, 2014 5:38 pm
by Rudi
Hi Achmed,
the same here. Octane Stand alone is empty.
Posted: Sun Aug 17, 2014 3:18 pm
by inlifethrill
It works as epxeced.
1. Enter the correct exe path in the Octane Settings/Other.
2. Make sure you click the resend scene information button (render) while still in Cinema 4D.
3. Go to the Octane Dialog Panel, File/Edit in Standalone. This will launch standalone automatically.
4. Once loaded, you should see a node tree - this is your scene.
5. Click/Select the bottom most node, it should read "Render Target"
You will see your scene rendering.
Hope this helps.
Dobs
Posted: Sun Aug 17, 2014 9:31 pm
by Yan
Thanks inlifethrill !
I was using the edit in standalone only with the octane dialog opened (no live rendering opened).
In other words you need the live window opened and the render in progress when you click edit in standalone :)
This is great :)
Posted: Sun Aug 17, 2014 9:39 pm
by aoktar
Yan wrote:Thanks inlifethrill !
This is great :)
hmm, i have mentioned about same thing.
Posted: Sun Aug 17, 2014 11:18 pm
by Yan
This is great :)
Sorry...I have read you message on my phone at the time you posted and didn't get the message quite right. My mistake :(
Posted: Fri Jul 31, 2015 3:27 pm
by tmcalvin
I've tried to get this to work quite a few times with no luck. I get the same result, empty standalone. I'm on osx c4d plugin 2.23.2 R6.2. I've pointed to the standalone app in the settings panel. I've tried resending the scene, waiting for the render to begin and then going to FILE/EDIT IN STANDALONE. Empty
I also have a semi-related issue. When I go to FILE/Export to/Standalone Scene (ocs) then enter my filename/location and hit save it will totally jack up my render view. It doesn't change anything in the c4d viewport but the live viewer is wrecked and what's exported matches.
Any suggestions would be super helpful. These issues combined have made it very hard to get any use from the standalone.
TC
