				Does the Poser Plugin 2.x work with the Standalone 1.2?
				Posted: Wed Aug 13, 2014 8:46 pm
				by homerice
				Does the OctaneRender™ for Smith Micro's Poser® 2.x plugin work with the Octane Student Standalone 1.2? If not, then I won't purchase the OctaneRender™ for Smith Micro's Poser® 2.x plugin. Thanks.
				Re: Does the Poser Plugin 2.x work with the Standalone 1.2?
				Posted: Wed Aug 13, 2014 10:44 pm
				by FooZe
				Hi Homerice, No you will not be able to run the 2.x poser plugin with a 1.20 only standalone license.
				Posted: Wed Aug 13, 2014 11:27 pm
				by homerice
				Got it. Would you be able to tell me which version of Poser plugin incooperate with standalone 1.2 and how I can get that version of Poser plugin? Thank you.
				Posted: Wed Aug 13, 2014 11:32 pm
				by FooZe
				Technically the 1.20 version of the poser plugin should work along side the 1.20 only student standalone license. You would need to purchase a full 2.x poser plugin license, but you will only be able to use version 1.20. You would get no updates, no bug fixes or support for this version either since work is currently done on the 2.x versions. You can find the old 1.20 install on the poser plugin forum.
http://render.otoy.com/forum/viewforum.php?f=45
				Posted: Thu Aug 14, 2014 12:20 am
				by homerice
				Hi FooZe,
I went to the link you provided but all those old versions of plugins prior to OctaneRender® for Poser (Windows) 1.50 [STABLE] are obsolete. Is there a way that I can get or purchase the version 1.2 poser plugin?
				Posted: Thu Aug 14, 2014 12:28 am
				by FooZe
				homerice wrote:Hi FooZe,
I went to the link you provided but all those old version of plugins prior to OctaneRender® for Poser (Windows) 1.50 [STABLE] are obsolete. Is there a way that I can get or purchase the version 1.2 poser plugin?
Sorry, this is a little tricky so i will try to explain a bit better!
The only poser license you can purchase is a 2.x one, but these are backwards compatible with 1.x octane versions.
Usually you would purchase a combo and have a 2.x standalone and 2.x plugin license. When you install the plugin it will ask for the plugin license, and then the standalone one.
In your case you have a 1.20 standalone license. If you were to purchase a 2.x poser plugin license, you could install the 2.0 poser plugin, enter the 2.x plugin license, and then the 1.20 standalone license. At this point it would tell you that this license will not work with version 2.x.
If you were to purchase a 2.x poser plugin license only, then install the 1.20 version of the plugin, then enter your 2.x plugin license and your free 1.20 standalone license, it should work.
You would need to find the 1.20 (obsolete) forum post and download this old version from the links inside the post.
Hope that makes sense?
Chris.
				Posted: Thu Aug 14, 2014 1:08 am
				by homerice
				Appreciate this detailed explaination. Now I fully understood the mechanism of installing different versions of standalones and plugins. Thanks.
				Posted: Fri Aug 15, 2014 11:39 am
				by ArminBeier
				I would advice you to buy the 2.x standalone license along with the poser plugin license.
Everything else would be a waste of money. If you are using Poser, I suppose you use displacement mapping, which isn't supported in 1.2, but it is in 2.x.
Just my advice.
				Posted: Fri Aug 15, 2014 1:34 pm
				by homerice
				ArminBeier, OK acknowledged. Thank you for your advice.
