Page 1 of 2
750ti
Posted: Mon Jul 21, 2014 10:13 pm
by MaTtY631990
Hi
Does the plugin version support the 750 and 750ti cards. Can't seem to get it working.
Re: 750ti
Posted: Mon Jul 21, 2014 10:53 pm
by Karba
MaTtY631990 wrote:Hi
What plugin version and drivers do you use?
Re: 750ti
Posted: Mon Jul 21, 2014 11:04 pm
by MaTtY631990
Hi Karba
1.53a and latest driver version 337.88. 1.55 won't install properly, I use 3dsmax 2011. I have not upgraded to octane 2.0 yet, and it is not a necessity for me at the moment. The standalone version 1.54 and above works fine with card.
Re: 750ti
Posted: Mon Jul 21, 2014 11:13 pm
by Karba
MaTtY631990 wrote:Hi Karba
What is the problem with 1.55?
Re: 750ti
Posted: Mon Jul 21, 2014 11:24 pm
by MaTtY631990
Error loading dlls
Octane3dsmax.dlr > failed to initialize
error code 126 - the specified module could not be found
Re: 750ti
Posted: Tue Jul 22, 2014 3:28 pm
by MaTtY631990
Not sure the 1.55 version would work as well with the card because someone else has issue with no memory being loaded for the card.
Re: 750ti
Posted: Tue Jul 22, 2014 9:13 pm
by Karba
1.55 should work with 750ti
Did you get any 1.55 installation errors?
You should have several files in 3dsmax root folder
octane.dat
octane.dll
vcomp100.dll
Re: 750ti
Posted: Tue Jul 22, 2014 9:28 pm
by MaTtY631990
All files are there but when I launch 3dsmax I get error.
Re: 750ti
Posted: Tue Jul 22, 2014 9:29 pm
by Karba
MaTtY631990 wrote:All files are there but when I launch 3dsmax I get error.
could you try to delete all of them and run the installer again?
what 3dsmax version do you use?
Re: 750ti
Posted: Tue Jul 22, 2014 9:31 pm
by MaTtY631990
3dsmax 2011, will run the installer again and double check.
