Aliasing issues
Posted: Thu Jul 17, 2014 1:18 pm
by Lewis
Hi!
Is there a way/function how we could avoid jaggy (aliased) edges on bright surfaces (reflections on a car and bright black body materials) in Octane rendering?
I tried to cover it by adding some bloom and glare but no luck it's still very visible.
Re: Aliasing issues
Posted: Thu Jul 17, 2014 1:22 pm
by prodviz
Those look like overbright values (so values over 1).
You can pull these areas back in, in compositing apps, but it'd be cool to have a clipping/burn/shoulder type function in Octane itself.
Re: Aliasing issues
Posted: Thu Jul 17, 2014 1:34 pm
by juanjgon
Perhaps you can also try use lower power emitters and add more exposure time or ISO in the scene. I am not sure if this could help.
Re: Aliasing issues
Posted: Thu Jul 17, 2014 1:44 pm
by Lewis
Yes they are certainly over 1 (HDRI) but in LW native there is option called "limit dynamic range" which deals with that problem nicely. I hoped there is way to do it in octane somehow also.
thanks i+ll try lower value plus more exposure although i'm pretty high there also already
Re: Aliasing issues
Posted: Thu Jul 17, 2014 1:58 pm
by Lewis
Ok i dialed back black-body material for ceiling lights (it was 5.0 now it's 1.0), added bit more exposure and adjusted gamma but i still see same jaggy edges on lamps and reflections.
Hmm, what elee is there to try
Re: Aliasing issues
Posted: Thu Jul 17, 2014 3:20 pm
by juanjgon
Lewis wrote:Ok i dialed back black-body material for ceiling lights (it was 5.0 now it's 1.0), added bit more exposure and adjusted gamma but i still see same jaggy edges on lamps and reflections.
All the scene looks a bit crisp. Perhaps you could add a bit of DOF effect, or change the "filter size" parameter (for example to 2.0) in the kernel to try to add more antialiasing to the scene.
Re: Aliasing issues
Posted: Sat Jul 19, 2014 3:09 pm
by BorisGoreta
Render at double resolution and scale down.
Re: Aliasing issues
Posted: Wed Jul 23, 2014 5:54 pm
by 3dworks
try the free OLMSmoother plugin - works really well in such cases.
http://www.olm.co.jp/rd/technology/tools/?lang=en
cheers
markus
