Hair thickness not working
Posted: Fri Jul 04, 2014 10:14 am
by Rikk The Gaijin
Hi, I'm trying to export a group of hair from 3dsmax through Ornatrix alembic exporter, the hair are exported correctly, except the thickness. If I DON'T specify the thickness in max, and then I export the hair, they come in HUGE, and the Octane parameter to specify the default thickness doesn't work!
Here is the file, if someone wants to take a look...
Re: Hair thickness not working
Posted: Mon Jul 07, 2014 12:31 am
by Rikk The Gaijin
Anyone?
Posted: Mon Jul 07, 2014 2:17 am
by FooZe
Here is what this looks like for me:
This is with 2.02, default meters scale and hair thickness (0.0001).
Seems ok for me?
Posted: Mon Jul 07, 2014 7:50 am
by Rikk The Gaijin
The problem is you cannot change the thickness. It doesn't matter what value I put in, it always looks the same... Can you confirm that?
Posted: Mon Jul 07, 2014 10:05 pm
by FooZe
Ahh, ok, sorry I thought the problem was that the hair was huge.
Yes I can confirm the default thickness does not seem to do anything for me either.
Is this the export with or without the thickness specified? (I'm guessing with?)
Posted: Tue Jul 08, 2014 1:09 am
by Rikk The Gaijin
FooZe wrote:Ahh, ok, sorry I thought the problem was that the hair was huge.
It is specified, yes, but even if I don't specify it, the hair come in huge, and the thickness parameter doesn't do anything. Can we have a "override thickness" option box in Octane?
Posted: Thu Jul 10, 2014 9:53 am
by Norman_Stansfield
Guys, is there any option to render hair directly from 3dsmax - by octane 2.0?
I mean standard hair and fur modifier.
Posted: Fri Jul 11, 2014 2:42 am
by Karba
Norman_Stansfield wrote:Guys, is there any option to render hair directly from 3dsmax - by octane 2.0?
use 2.02 version of 3dsmax plugin. there is an option in render settings - "standard hair&fur support"
