geomerty problem
Posted: Wed Jun 18, 2014 9:40 am
by Jorgensen
Hi
I have a simple chair that I would like to use, but it seems that Octance fails to render the chair :-/
It seems to happen when two curved faces are near each other.
Is there somekind of workaround?
Re: geomerty problem
Posted: Wed Jun 18, 2014 1:00 pm
by resmas
hello mate.
Can you send me the chair? it looks like maybe normal are inverted or duplicated mesh.
In StandALone how does it render?
cheers
resmas
Posted: Wed Jun 18, 2014 1:41 pm
by Seekerfinder
Jorgensen wrote:Hi
Check the normals.
Play with scale.
Let us know if that helps.
Seeker
Posted: Wed Jun 18, 2014 5:50 pm
by fuzzybro
Hi Jorgensen,
If nothings helps try right-click on the geometry and select "Octane Mesh". In opened dialog select "load normals - false". This will force octane to recalculate normals instead of loading them from SU.
Hope that helps
Bro
Posted: Wed Jun 18, 2014 8:57 pm
by Jorgensen
hi fuzzybro
thanks - that seems to fix the problem
thank you
Posted: Wed Jun 18, 2014 10:01 pm
by fuzzybro
Great!
SU can screw geometry up sometimes, so use this trick to fix bad geometry.
Cheers!
