Page 1 of 2
Open Subdiv crash
Posted: Fri Jun 13, 2014 8:53 am
by CANDITO
Hi there,
opensubdiv keeps crashing when i try to use it
(the sample scene as well as other tests i did)
Am i the only one with this issue?
I'm on Windows 8, LW 11.6.1
Thanks a lot
Oliv
Re: Open Subdiv crash
Posted: Fri Jun 13, 2014 9:12 am
by juanjgon
CANDITO wrote:Hi there,
Thanks a lot
Oliv
Do you have a crash with the sample scene available in the .zip file?
Posted: Fri Jun 13, 2014 9:28 am
by CANDITO
Hi Juanjo,
yes it crashes when updating GPUS
Oliv
Posted: Fri Jun 13, 2014 9:40 am
by juanjgon
Here it works fine, no problems so far. Are you sure that you have not changed anything in the scene, or do you have any other problem with the plugin?
Are you using the x64 plugin?
Anybody else can test the sample OpenSubDiv scene to see if it works?
Posted: Fri Jun 13, 2014 9:46 am
by scratch33
Works fine here.
Just opened and tried with ipr then rendered.
No problem
Posted: Fri Jun 13, 2014 10:02 am
by CANDITO
Yes, i'm using the X64 plugin
and the sample scene hasn't been changed...
IPR and F9 crashes
For the moment everything else works fine.
The only strange thing i noticed (but may be it's the normal behavior of it)
is the displacement maps exploding the polygons when applied to other things than a simple plane,
like if the polygons where not attached to each other.
For the opensubdiv, is there an error log somewhere that i could send you?
Oliv
Posted: Fri Jun 13, 2014 10:08 am
by juanjgon
CANDITO wrote:Yes, i'm using the X64 plugin
IPR and F9 crashes
Oliv
Yes please, enable the log file in the plugin options panel and send it to me.
Are you sure that the objects with displacement that explode the polygons have the vertex welded?, can you post a screengrab or a sample scene?
Posted: Fri Jun 13, 2014 10:35 am
by CANDITO
Ok i updated the drivers of my graphic cards with the last version
and now the opendubdiv works fine :)
For the displacement, below is what i get when i apply
the mountain displacement to a sphere (all points are welded)
Thanks again for your help
Oliv
Posted: Fri Jun 13, 2014 11:08 am
by juanjgon
You need to enable the smoothing parameter in the Ligthwave material. Without this parameter enabled the object doesn't have the Lightwave normals and the displacement doesn't work.
Posted: Fri Jun 13, 2014 11:17 am
by CANDITO
Thanks very much Juanjo!
