OctaneRender® for 3ds max® v1.50
Posted: Mon Apr 07, 2014 3:31 am
				Main changes since version 1.20
Rendering
Installer http://www.refractivesoftware.com/plugi ... p_1_50.zip (25MB ZIP File)
Yours,
The OctaneRender® Team.
			Rendering
- Added support for object properties to control the direct/indirect visibility of objects via object layer map nodes.
- Added general support for various texture projections: UV, spherical, cylindrical, linear, perspective, box mapping.
- Added ability to apply an additional transformation in the mapped UVW space.
- Added ability to apply the texture projection in local object (/instance) space.
- Added border modes to image texture nodes to control the behavior of image textures outside the standard UV range [0 .. 1].
- Improved wire frame rendering of the info channel kernel.
- Added the possibility to set the value of greyscale color texture nodes to values > 1, which can be helpful to set higher bump strengths than previously possible.
- Increased the maximum render resolution to 32K x 32K pixels.
- Camera motion blur.
- Gradient texture support.
- Xref support.
- Using render settings for mesh/turbo smooth modifiers.
- Camera correction modifier support.
- Clay render option.
- Image texture reloading button.
Yours,
