Worksession renders?
Posted: Fri Mar 21, 2014 3:02 pm
by simsy73
Is it possible to render with octane using worksessions?
When I have tried, the only geometry visible in the octane viewport is the active model. All referenced models are invisible?
Can I control which references are visible in the octane viewport?
Re: Worksession renders?
Posted: Fri Mar 21, 2014 9:01 pm
by face_off
I haven't tried this yet. Let me investgate and get back to you afer the weekend.
Posted: Mon Mar 24, 2014 5:07 am
by face_off
I have looked into rendering in Worksessions - and at this stage the plugin does not support this. I have escalated this to McNeel to see if there is a solution.
Posted: Mon Mar 24, 2014 4:49 pm
by simsy73
thanks for looking into it
Posted: Wed Mar 26, 2014 10:57 pm
by face_off
I have been able to get Worksessions supported in the plugin (with McNeel help). Can you pls try the plugin version at
http://render.otoy.com/customerdownload ... _64bit.exe. You will need Rhino SR8.
1.50.0.16
- Added support for Worksessions. Attached scenes will need their Octane materials already defined (ie. you cannot edit the Octane material of an attached scene object in the worksession).
