Hair
Posted: Tue Mar 18, 2014 10:17 pm
by Sorel
What are some material setups people use for hair?
Re: Hair
Posted: Wed Mar 19, 2014 6:33 am
by t_3
from my experience a rather simple setup usually works good, like a diffuse material with diffuse/bump/opacity maps, plus a simple color in the transmission pin. maybe an additional mix with (very) little amount of a similar set up glossy material.
for more control of the color a rgb node for the diffuse map power is also helpful. in such a setup the key parameters to edit would be rgb diffuse map power, diffuse map gamma and transmission color; bump usually set to a rather high value...
Re: Hair
Posted: Wed Mar 19, 2014 4:19 pm
by Sorel
Thank you for the reply. I will do some testing with this.
