Error Texture Material Render - Blender
Posted: Sun Jan 05, 2014 7:52 pm
by Jer_Bear
I think there's a problem with the blender octane image map rendering.
Images don't render.
https://www.dropbox.com/s/a7v9sxf2eqpco ... .25.22.png
https://www.dropbox.com/s/gf6eb8jp8y61x ... .28.35.png
it's very frustrating
Re: Error Texture Material Render - Blender
Posted: Sun Jan 05, 2014 8:01 pm
by mib2berlin
Hi, did you unwrap the objects?
Images only work with objects have a UV map in Blender Octane.
You could post .blend (with packed textures) here:
http://www.pasteall.org/blend/
I can look in it.
Cheers, mib.
Posted: Sun Jan 05, 2014 8:08 pm
by JimStar
Posted: Mon Jan 06, 2014 3:26 am
by Jer_Bear
Hey guys
Ya, i know. Unwrap, install the plugin...ect...
Really i think it's a problem with the plugin.
For now i'll just export it into octane for the final texture rendering but it's just something that i think is worth taking into consideration.
Maybe mentioning it to Lionel, idk.
anyway, have a nice day. :)
Posted: Mon Jan 06, 2014 3:50 am
by FooZe
Jer_Bear wrote:Hey guys
Hi Jer,
JimStar is the developer of the Blender fully integrated plugin.
There should be no need to export it into the standalone.
Just hit tab to goto edit mode, hit U and click unwrap, then exit edit mode.
(The UV's will be updated to octane until you exit edit mode).
If that does not work then please post the .blend file.
Chris.
Posted: Mon Jan 06, 2014 4:33 am
by Jer_Bear
Hey Chris.
Btw the plugin is still very good. Txs Jim.
It's very possible there might be a problem with my windows folders, there was a similar problem with an error message i had
Anyways, here's the file. As is the .jpg map doesnt render.
https://www.dropbox.com/s/j6p4y3j6tgyg9tm/Testbox.blend
Jeremy
Posted: Mon Jan 06, 2014 4:58 am
by FooZe
Strange, this will work fine for me, i just need to unpack the jpg (i'm also using version 2.8 or the plugin).
If you have had path/filename problems before then yes, please place the image in a simply named folder on a main drive that you also know there will be no access rights problems.
Chris.
Posted: Mon Jan 06, 2014 5:55 am
by Jer_Bear
Thought so...i'll try to figure out the problem...let u guys know.
I'm running on windows 8 with all my files saved to dropbox.
pc
