Problem with daylight Tag
Posted: Sat Dec 14, 2013 5:13 pm
by cglittenberg
I have a problem with the daylight tag. Changing the time or date does not have an effect. It will just stay with the lighting that was when you created the tag. Is there a work around?
Re: Problem with daylight Tag
Posted: Sat Dec 14, 2013 5:21 pm
by aoktar
cglittenberg wrote:I have a problem with the daylight tag. Changing the time or date does not have an effect. It will just stay with the lighting that was when you created the tag. Is there a work around?
be sure it's enabled
Posted: Sat Dec 14, 2013 5:23 pm
by cglittenberg
aoktar wrote:cglittenberg wrote:I have a problem with the daylight tag. Changing the time or date does not have an effect. It will just stay with the lighting that was when you created the tag. Is there a work around?
What do you mean? Where?
I just created a sunlight tag in the Octane dialog. The sky was created just fine. The sun renders correctly. I just cant change the time. Where do I enable?
Posted: Sat Dec 14, 2013 5:32 pm
by aoktar
it has suntag and default is disabled. You must activate
please check last image in page:
http://render.otoy.com/manuals/Cinema4D/?page_id=104
Posted: Sat Dec 14, 2013 5:44 pm
by cglittenberg
