Batch Rendering Named Views
Posted: Wed Nov 06, 2013 11:54 pm
by polywog7
Hi all,
I'm not sure if this has been addressed already but I'm wondering if anyone has any tips on using octane to batch render a series of named views.
I've had pretty good luck using this script while rhinos render is set to octane:
http://www.rhinoscript.org/scripts/50
Only things that I haven't figured out is that it seems to close and voxelize the scene between each named view, and I haven't been able to make it save to a png instead of a jpg.
Anyone else have any input or other methods for this?
Re: Batch Rendering Named Views
Posted: Thu Nov 07, 2013 12:09 am
by face_off
If you open the viewport prior to rendering with the batch script, that should result in the scene not having to be reloaded each frame (since it will pickup the rendertarget from the Viewport). Also, there is a checkbox in the plugin Settings called "Scene Refrehs on View Change" - make sure this is unchecked.
Regarding the save format, that will be controlled by the script. You can probably just edit the script to change jpg to png.
Posted: Thu Nov 07, 2013 12:21 am
by polywog7
Hey Paul,
Seems that if I open the octane viewport, then run the rhino render on its own, or that script, it first closes the octane viewport then still proceeds to voxelize for the rhino render window and each batch named view as well . Not sure if there's anything else I'm missing. I have the view change box unchecked.
Posted: Thu Nov 07, 2013 12:45 am
by face_off
Sorry - I should have mentioned, you need to tick the "Use Viewport Rendertarget Geometry When Rendering :" checkbox in the Settings.
Posted: Thu Nov 07, 2013 1:12 am
by polywog7
Ah great, that seems to be the ticket!
So does that just mean that it's going to use the same geometry or is it taking any camera target information etc with that box checked? Any adverse effects in other uses having that box checked?
Posted: Thu Nov 07, 2013 1:32 am
by face_off
It won't reload the scene into Octane with that checkbox clicked. So if a different camera has different geometry visible, that geometry change won't be reflected in the Octane render - since it is just reusing the same rendertarget. If you have moving geometry, just untick that box, and then the rendertarget (and geometry) will reload. You /might/ also be able to set Live Geometry on for meshes that are moving (if you are animating) and they might update between frames - but I haven't tested that.
