Page 1 of 2
				alien skull/testing procedurals
				Posted: Sun Oct 20, 2013 10:30 pm
				by acc24ex
				made this little guy while zbrushing/doodling
- now the material is all procedural but in 3dmax - is there ever going to be a way to upload those into LifeDB ?
- I've used a bit of dirt there, turbulence and falloff for the diffuse an marble for the bump, brings out the details quickly
- also a bit of a run at the water scene from previous post - I just made a quick moby dick, now it would be cool to do one underwater
				Re: alien skull/testing procedurals
				Posted: Mon Oct 21, 2013 10:34 am
				by acc24ex
				Posted: Mon Oct 21, 2013 6:35 pm
				by acc24ex
This isn't even my final form..
				Posted: Mon Oct 21, 2013 9:19 pm
				by NVN
				Nice, i like!
				Posted: Tue Nov 12, 2013 11:21 am
				by niuq.cam
				Excellent. Really greats tests.
				Posted: Tue Nov 12, 2013 2:11 pm
				by Jorgensen
				Wow - really nice made renders / models..
maybe one should just try zbrush or mudbox for fun..
do you know if sculptris is any good?
				Posted: Wed Nov 13, 2013 10:59 am
				by dionysiusmarquis
				I would love to see the metal ones in LiveDB!
				Posted: Wed Nov 13, 2013 3:48 pm
				by acc24ex
				Jorgensen wrote:Wow - really nice made renders / models..
- sculptris is great, I recommend it, the guy that made it works for zbrush now - it's the best way to learn zbrush, just use big move brushes for the primary shape, and sculpt on, you can transfer to other applications via goz (including zbrush) that is built into all of those.. mudbox is great, the UI is something you are more used to, but zbrush is the mother of all IMHO, and is more fun once you get the hang of it..
- and I would also like to add the metal material to octane database - but I have to transfer it all frrom 3dmax to octane standalone, and not sure how to upload from there anymore..
- another thing is, it acts differently on different size models - this was actually to big of a scale - and the procedural noise is not good for animation unless the object is static.. found out after doing a turntable - noise stays static
- but basically add subtle noise to all levels, for reflection, mix it in with falloff and dirt, and bump.. then set it to glossy index of 1 - my setup got very complicated very quickly..
- change the glossy index and get the dirtz
				Posted: Wed Nov 13, 2013 5:03 pm
				by dionysiusmarquis
				It seems in Octane 1.5 it will be possible to convert Plugin setups to Octane files.
"To allow plugins to hide the complex node setups they create in a node graph so that they will eventually be able to export a scene into an OCS file that can be opened and used in Octane standalone."
				Posted: Thu Nov 14, 2013 4:32 pm
				by acc24ex
				yes.. that's what I read as well.. until it comes out
anyways - here's a node setup - I guess for all of the materials, the trick is in combining the fallofs with dirt and noise - objects get that much more expression - I think I'll try and use this kind of setup for everything
nodez:
end up with something like, all using the same node setup
and all of above
