Black pattern on glass materials
Posted: Tue Oct 08, 2013 6:57 pm
by Rudi
1. Material Specular
I provide a glass with engraving from Normally Map.
2. Material Diffuse
I provide black/white pattern
3. Material mix material
The first one and the second material are brought together.
Indeed, I do not succeed in filling the engravings with Black.
What must I do?
Or does this not go? What I do not hope really and think.
Re: Black pattern on glass materials
Posted: Tue Oct 08, 2013 8:48 pm
by aoktar
you should'nt use float texture on mix material. A image is best choice which is similar to like in second image
Posted: Wed Oct 09, 2013 6:36 pm
by Rudi
aoktar wrote:you should'nt use float texture on mix material. A image is best choice which is similar to like in second image
My english is not the best. It is to be maintained really hard me in it or to understand.
How do I do this? Nevertheless, Float is present everywhere.
The black must be also not black maybe gold or anything else. It should look massively on glass.
Unfortunately, one has in the glass canal (Specular) nobody Vaguely. With it I could lay a texture about the glass.
But thus I simply do not do.: (
Posted: Wed Oct 09, 2013 7:23 pm
by roeland
You have to use the texture with the black/white pattern as the "amount" input of the mix material. The second material input of the mix material should be a black diffuse material.
Roeland
Posted: Thu Oct 10, 2013 2:55 pm
by Rudi
Oh man,
it is this.
I had taken a completely wrong way.
With mix material not 2 textures are mixed, but 3. I have not known that also a texture comes in Amount. Now it is perfect
