poser plugin problem.
Posted: Mon Oct 07, 2013 10:16 pm
by spartan00j
hello i have the demo plugin for poser. my Ambient or alternate diffuse values is not showing up in my octane renders.
Re: poser plugin problem.
Posted: Mon Oct 07, 2013 11:46 pm
by face_off
Hi
There is not a 1-to-1 correlation between Poser and Octane materials. Instead the plugin converts Poser materials to Octane materials according to a set of rules (which I think are listed in the manual). For most materials, this conversion will bring across all info, but for some Poser materials, the node structure will be such that the plugin will only bring across a subset of the info, so for these materials you will want to adjust the Octane material to get the right look in your render. This is generally very quick and easy to do, but requires some knowledge of Octane.
Specific to your question.....
If ambient_value is > 1, then the material will be converted to an Octane diffuse emitter, otherwise the ambient is ignored.
From memory, alternate diffuse will be converted to the Octane diffuse IF there is no normal diffuse (ie. the top diffuse in the Poser material takes precedence over alternate diffuse.
Posted: Tue Oct 08, 2013 12:27 am
by spartan00j
so how do i add a ambient like texture in the octane plugin.
Posted: Tue Oct 08, 2013 2:24 am
by spartan00j
okay i figured out how to do it. thanks. i'm really liking this render i wish it didn't cost so much. :( but i guess if you want a great tool you need to spend alittle more. :lol:
