OctaneRender™ for Blender 1.20.2 - 2.3 beta Linux [OBSOLETE]
Posted: Fri Oct 04, 2013 6:46 am
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just run the installer.
- If you need to run the OctaneServer - run it as daemon:
DOWNLOAD
Blender Octane Edition - v2.3 beta Linux (128MB autoinstaller file)
- Implemented automatic installator for this plugin. Now you can just run the downloaded file to install it.
- Added new Blender space editor type: "Materials LiveDB". Getting material from LiveDB is asynchronous - it does not block user interface. You can choose object, press "Get item" button, and work with scene... When material will be downloaded - it will be set to previously choosen object in background. Blender material is created automatically by LiveDB if Object still does not have material assigned at the time of loading material from LiveDB server.
- Added material preview feature. As OctaneServer is not able to render two sessions in parallel - if you will take the material preview rollout open, you will not be able to start live render or F12 render before material preview will be ready (it renders at 100 samples per pixel).
- Login-password disappear from input fields now only after successful sending to the server.
- Improved system console and on-screen feedback messages from OctaneServer.
- Minor bug fixes...
Installation:
# OctaneServer &DOWNLOAD
