OctaneRender™ for Blender 1.20.2 - 1.4 beta Linux x64 [OBSOLETE]
Posted: Fri Aug 30, 2013 4:47 am
The TEST Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just copy the files from archive to root file system (into the same folder-tree as in archive).
- Run the OctaneServer as daemon:
- Now you can start blender.
- If you got error messages that blender needs some libBlahBlah.so library - you can run the install_deps.sh script from installed blender folder with appropriate command-line keys. It will download, compile and install all needed libraries. If you dont want to install only the needed libraries - you can install all possible using --with-all key (but be ready it may take a lot of time to download, compile and install them all).
DOWNLOAD
Blender Octane Edition - v1.4 beta Linux (91.8MB archive file)
Installation:
# OctaneServer &- If you got error messages that blender needs some libBlahBlah.so library - you can run the install_deps.sh script from installed blender folder with appropriate command-line keys. It will download, compile and install all needed libraries. If you dont want to install only the needed libraries - you can install all possible using --with-all key (but be ready it may take a lot of time to download, compile and install them all).
DOWNLOAD
