Page 1 of 2
How about R12?
Posted: Wed Sep 08, 2010 9:10 pm
by mantra
subj ;)
Re: How about R12?
Posted: Thu Sep 09, 2010 10:12 am
by abstrax
mantra wrote:subj ;)
Yup, the next version will run on R12, too. I didn't have much time the last days, so 0.10 is not finished yet, but I hope it's not far away anymore.
Does anyone already have the R12?
Cheers,
Marcus
Re: How about R12?
Posted: Thu Sep 09, 2010 10:15 am
by mantra
if you need for tests, u can download from http://www.maxon.net full worked demo
u can make it in the python also
Re: How about R12?
Posted: Thu Sep 09, 2010 11:19 am
by abstrax
mantra wrote:if you need for tests, u can download from http://www.maxon.net full worked demo
I've got R12 running here, that's no problem, but I will not rewrite the exporter in Python. Two reasons for that: Speed and backwards compatibility.
I was just curious, if actually someone uses already the R12 ;)
Cheers,
Marcus
Re: How about R12?
Posted: Thu Sep 09, 2010 1:38 pm
by mesut
abstrax wrote:...
Cheers,
Marcus
yes.
Re: How about R12?
Posted: Thu Sep 09, 2010 2:24 pm
by e3di
I'm running R12 as well..
Re: How about R12?
Posted: Thu Sep 09, 2010 8:25 pm
by abstrax
Hi all,
just to let you know: I have starting on the work to make the exporter code compatible with R12. As it's a tedious process, I'm sharing my dev time between new feature things and the R12 port. The reason, why porting the code to R12 takes that long is, that I want to keep it backwards compatible back to R9.6, which means that I have to put in fallback code for the older versions. Otherwise it would probably be be done already.
Cheers,
Marcus
Re: How about R12?
Posted: Thu Sep 09, 2010 10:49 pm
by bepeg4d
Take your time Marcus and thanx for the great work you are doing ;)
ciao beppe
Re: How about R12?
Posted: Fri Sep 10, 2010 5:45 pm
by mantra
now i'm using r12 too!
Re: How about R12?
Posted: Fri Sep 10, 2010 9:18 pm
by abstrax
I'm now half way through the port ... ;)
Cheers,
Marcus
