The maximum amount of the GPU in a single station?
Posted: Mon Jul 01, 2013 7:25 pm
by flysats
Good day!
I have a few questions to create a powerful render stantion.
Pre-configuration contains 10GPU nvidia gtx titan gtx. (Or 20 gpu 670gtx)
question:
Allow as many gpu, octan render?
Is there a limit on the number of GPU?
Is there a limit on the amount of the GPU drivers from nvidia?
Will I get a linear acceleration rendering in multiples of GPU?
What methods of scaling expected to be introduced? Will the network rendering to multiple workstations?
Re: The maximum amount of the GPU in a single station?
Posted: Mon Jul 01, 2013 10:52 pm
by abreukers
hi, the speed increments you get when you add gpus is almost linear (e.g. rendering with four GTX Titans will be 4x faster than using only 1 GTX Titan). As for the drivers, this depends on the machine setup, of course they should make all the pieces work together. Octane requires a recent Nvidia driver for your platform, the cards for rendering should be cuda-enabled but can be a combination different models (e.g. 680+690+titan+780)...
Posted: Tue Jul 02, 2013 12:12 am
by flysats
I'm worried that Nvidia blocked or restricted, for marketing reasons, configurations with more than 8 GPU (at least on the consumer level cards). Unfortunately able to check I have not, I figured that since you are working closely with Nvidia you have this information. It can be specified?
Posted: Tue Jul 02, 2013 7:08 am
by gabrielefx
build 2 Tyan barebones with 8 Titan each
Posted: Thu Aug 22, 2013 11:29 pm
by machineyes
Hey Gabriel,
Are the Tyans you're talking about setup on servers or expansion boards off of your pci slots? Could you send me a link to the exact model of Tyan you're talking about?
Thanks so much!
Posted: Fri Aug 23, 2013 11:30 am
by glimpse
there are treton systems too, You can either have with pcie expansion or host board options. http://www.trentonsystems.com
