Page 1 of 2
Octane exporter for C4D version 0.09
Posted: Sun Aug 15, 2010 9:01 am
by abstrax
Hi all,
As promised here comes version 0.09. It has been a while since the last version, because I didn't have much time to work on the exporter plugin. The main changes are a new GUI layout with a fancy banner and a close button (hi Mac users ;) ). I have also added a new command plugin that allows you to export the scene and launch the Octane renderer without opening the export dialog.
For Macs I have changed the way Octane is launched - now it should detect the opened Octane application more reliably. Now animation rendering should also happen in the background, if you are using a Mac. (I don't know how to keep Octane from grabbing the focus on Windows.)
Internally I did some major restructuring - I hope I didn't break anything. Please let me know, if I introduced any bugs or problems.
EDIT: Unfortunately project names with strings are not cleaned up correctly anymore. I just found out and will fix this tonight and release a small bugfix update. Until then please don't use spaces in project names.
These are the PC builds of the plugin:
CINEMA 4D R9.6 (32/64bit):
OctaneExport_0.09_win_r9.6_release.zip
(187.88 KiB) Downloaded 436 times
CINEMA 4D R10.1 - 11.0 (32/64bit):
OctaneExport_0.09_win_r10.1_release.zip
(188.79 KiB) Downloaded 423 times
CINEMA 4D R11.5 (32/64bit):
OctaneExport_0.09_win_r11.5_release.zip
(266.45 KiB) Downloaded 497 times
These are the Mac builds of the plugin:
CINEMA 4D R9.6 (32bit):
OctaneExport_0.09_mac_r9.6_release.zip
(125.61 KiB) Downloaded 387 times
CINEMA 4D R10.1 - 10.5 (32bit):
OctaneExport_0.09_mac_r10.1_release.zip
(163.81 KiB) Downloaded 424 times
CINEMA 4D R11.0 (32/64bit):
OctaneExport_0.09_mac_r11.0_release.zip
(333.55 KiB) Downloaded 411 times
OctaneExport_0.09_mac_r11.5_release.zip
(361.84 KiB) Downloaded 455 times
Happy rendering,
Marcus
Re: Octane exporter for C4D version 0.09
Posted: Sun Aug 15, 2010 10:08 am
by pdavid
thank you for good work
Posted: Sun Aug 15, 2010 11:04 am
by Perdition
Thanks! 8-)
Posted: Sun Aug 15, 2010 8:36 pm
by acc24ex
That's a great looking exporter.
How do we set the material in c4d so it has texture emission turned on in octane?
Posted: Sun Aug 15, 2010 10:52 pm
by abstrax
acc24ex wrote:That's a great looking exporter.
I don't know yet how those new things will be integrated into the export workflow. -> For now you have to create a material for emitter objects and then modify the material in Octane to make it emit light.
Cheers,
Marcus
Posted: Tue Aug 17, 2010 2:05 pm
by hashmi74
Can someone explain how I can retain my existing lightning from C4D? as well as existing materials or do these have to be recreated in Octane?
I'm using C4D 11.008 on a mac.
thanks
p.s. I've taken a look at the Maya exporter video and there is no indication of this other than the use of daylight.
Posted: Thu Aug 26, 2010 11:08 pm
by clement
thx Marcus ! :)
Posted: Fri Aug 27, 2010 9:46 am
by sylvain
Thank you, great job :)
Posted: Fri Aug 27, 2010 7:53 pm
by atome451
Thanks a lot Abstrax.
Very good job.
Posted: Mon Sep 13, 2010 7:22 am
by dadou351
Hello,
It's a great work for this exporter thanks :)
I'm a little pb : when i want export and render my project, the textures are not in Octane Render. Do you know why it don't work ? Have you got a solution about this ?
Thanks again for this job ^^
David
