Page 1 of 2
				Question: SSS Skin & Alphashadows & hair
				Posted: Sun May 05, 2013 7:55 pm
				by JeffGalloway
				I have seen on this board that you need Alphashadows disabled to get a good SSS effect for skin. (I've tested it for myself and it is true, alphashadows enable kills the SSS effect)
But disabling Alphashadows created a big problem for transmapped hair, eyeleshed, etc.
How do you get around this issue?
				Re: Question: SSS Skin & Alphashadows & hair
				Posted: Sun May 05, 2013 8:24 pm
				by ch0pper
				Alphashadows disabled ]
I have never disabled these whilst rendering, but I will have a play and see what I can comeup with, never really had a problem as all my renders seem to have this enabled. Maybe you could post some of your findings be interested to see what your pictures look like
				Posted: Sun May 05, 2013 9:06 pm
				by face_off
				There was an SSS fix put through in Octane 1.13 too - so this might be different on that version.  If not - then it is a general Octane issue and should be reported to Otoy.
				Posted: Sun May 05, 2013 9:27 pm
				by JeffGalloway
				Example Issue. This is done (with the poser plugin) in v1.13
				Posted: Sun May 05, 2013 10:12 pm
				by KleanZlate
				JeffGalloway wrote:Example Issue. This is done (with the poser plugin) in v1.13
Have you tried setting Absorption and Scattering to 0 and Phase=Scattering Direction to 1?
				Posted: Mon May 06, 2013 3:40 am
				by JeffGalloway
				KleanZlate wrote:Have you tried setting Absorption and Scattering to 0 and Phase=Scattering Direction to 1?
Yes, I have tried that - and it does not give the same effect that I am getting with alphashadows disabled. There is something about the alphashadows enabled that deadens the SSS effect especially in the large volumes of the body.
				Posted: Tue May 07, 2013 5:16 am
				by face_off
				Thanks for the comparison image - very useful.  I have escalated this issue to Otoy.
				Posted: Fri May 10, 2013 9:42 pm
				by face_off
				Otoy have looked at this, and been able to reproduce the problem in Octane Standalone, so it will be fixed in a future release.
				Posted: Sat May 11, 2013 12:11 am
				by JeffGalloway
				That's good news!
				Posted: Wed May 22, 2013 3:41 pm
				by JeffGalloway
				Can you tell from this:
http://render.otoy.com/forum/viewtopic.php?f=33&t=32582
...if the fix for the above issue made it into this (1.15) release?
