Light Color
Posted: Thu May 02, 2013 12:19 am
by bpzen
Hi all
I am trying to get a red glow from a light, candels, i set up a point light in poser, ran the script to create the emmiter and picked a red color for the diffuse color but the light seems white still
Is there any documents / posts for how to get these colors to work?
Also, I set the opacity to 0 because the emitter was showing - is this teh right thing to do to not show the sphere that is the emitter?
PS - on a side note after a day and half using Octane + plug in its the best $$ i have spent on this hobby. I wish I got it sooner. I waited for reality / poser to be out, this blows that away.
Re: Light Color
Posted: Thu May 02, 2013 1:57 am
by UnCommonGrafx
Use a texture emitter instead of the blackbody emission model. With it you can color the light.
Re: Light Color
Posted: Thu May 02, 2013 2:27 am
by bpzen
arnt the lights that the script creates form the poser set texture emitters?
Re: Light Color
Posted: Thu May 02, 2013 3:41 am
by KleanZlate
Try setting the emitter to blackbody and lower the temperature value. The default value is 6500 but you could try between 3000 and 4000.
Re: Light Color
Posted: Thu May 02, 2013 4:08 am
by face_off
If you use the Crate Emitters from Lights script, it will create emitter planes for each light in the scene. In the plugin, Materials tab, select an emitter - you can change the emission color by changing the "emission"->"efficiency or texture" color.
