				First interior rendering with octane
				Posted: Mon Mar 04, 2013 6:59 am
				by ashurao
				Hello,
It is never easy to present his work (in progress) to the judgment of the others, but it helps to progress. So, do not hesitate to criticize.
The scene was done with Archicad, Cinema 4D and of course Octane Render.
Lighting is provided by the daylight. Then I played with the ISO settings, I'm 400.
The first image uses diffuse directlightning setting.
The second PMC setting.
Here! your advice and criticism are welcome.
				Re: First interior rendering with octane
				Posted: Mon Mar 04, 2013 9:30 am
				by wastzzz
				both are good, maybe the DL is better here, more depth
				Posted: Wed Mar 13, 2013 11:43 pm
				by jmfowler
				I much prefer the PMC version, DL is always too dark for areas away from direct lighting - hence the inside of the kitchen looks much darker than it would it real life.
JF.
				Posted: Fri Mar 15, 2013 9:02 am
				by ashurao
				hello,
thank you for your answers.
Your two opposing views reflect exactly my difficulty in choosing the best solution for realistic lighting. I have attached an overview of the 3D model, to show you the three openings that allow light to enter the room.
I agree with wastzzz, there's more depth with the lighting in direct sunlight.
But the whole is really dark. Maybe I should increase the ISO?
				Posted: Sat Mar 16, 2013 11:46 am
				by john_petrucci
				ashurao wrote:hello,
Very good image!
What is the "power" of the daylight environment???
Do you screen setting??
Iso setting?? 100???
				Posted: Sun Mar 17, 2013 3:58 am
				by PAQUITO
				Working in AO mode, you can fake that darker areas to make them look more luminous. Just decrease the AO distance until you dont see dark shadows. Fine tune the AO distance is always a good idea.
				Posted: Sun Mar 17, 2013 1:22 pm
				by ashurao
				john_petrucci wrote:
Very good image!
I have not changed the settings of "power" of the daylight environment. It's 1. And I increased the ISO to 500 and not 400 as I wrote in my first message.
				Posted: Sun Mar 17, 2013 1:29 pm
				by ashurao
				PAQUITO wrote:Working in AO mode, you can fake that darker areas to make them look more luminous. Just decrease the AO distance until you dont see dark shadows. Fine tune the AO distance is always a good idea.
I do not work AO mode, but diffuse. I find the AO too dark.
But I will try to follow your advice and see the result.
