SOME BASIC QUESTIONS FROM NEWBIE !!
Posted: Mon Dec 24, 2012 5:11 am
by awsjolie
1/ How to create a carpet with fur for octane render ?
2/ how to use daylight inviroment for octane render ?
3/ How to use instance with octane ?
All just to work with 3dsmax, certainly.Anyone can show me the way :) ?
Re: SOME BASIC QUESTIONS FROM NEWBIE !!
Posted: Mon Dec 24, 2012 6:51 am
by gzavye
With haïr and fur, convert to géomètry to render.
Daylight system Is under octane section in control panel, create, lights
For instances, right clic on object, octane proporties and check radio button.
Posted: Fri Dec 28, 2012 5:58 pm
by awsjolie
gzavye wrote:With haïr and fur, convert to géomètry to render.
Wow thanks alot :o !!!!!
Ive got 1 and 2 but still confused about how octane proxy work? what difference between ticking and not at movable proxy box?
Posted: Sun Dec 30, 2012 5:19 pm
by darkline
octane movable proxy allows the object to move interactively in the octane animation window.
If you do not check this button the mesh will remain in the same place as you scrub the animation bar or move it. You would have to reload the viewport every time you want to see a change.
So set lights and all objects to movable proxies and you get a far more interactive workflow as you move things around or change lighting.
Posted: Thu Jan 10, 2013 7:11 pm
by awsjolie
wow thanx alot. Very usefull ^^!!
Posted: Sat Feb 02, 2013 9:25 pm
by criko3d
really nice trick!, does it work with deforming meshes too??
