Page 1 of 2
Reflective SSS Material
Posted: Wed Dec 05, 2012 9:51 pm
by oguzbir
Hi Guys,
I added a glossy reflective SSS material I created earlier.
You can find at Live DB. Organic/Skin under the name Reflective SSS.
Let me know if you come up with nice renders with it.
Cheers,
Re: Reflective SSS Material
Posted: Wed Dec 05, 2012 9:58 pm
by Elvissuperstar007
goood !!!
Posted: Wed Dec 05, 2012 10:35 pm
by Slayerma
Nice render and mat.
Posted: Wed Dec 05, 2012 10:57 pm
by cfrank78
It works in Standalone but not in 3ds max. Hopefully i did everything right. In Standalone Light shines through, in 3ds not. Material looks simply Amazing! Tried it with a Ring - it look 1:1 lice cnc cutted Wax. Perfect :-)
Posted: Wed Dec 05, 2012 11:25 pm
by oguzbir
Thanks guys
@cfrank78
I'll look into how it performs in max.
In the mean time be sure to check your scene scale cause SSS tends to work best in real life scales.
I usually try to create my mat library in standalone.
I'm also happy to see that my render is in Octane renders Facebook
Posted: Thu Dec 06, 2012 2:33 am
by oguzbir
cfrank78 wrote:It works in Standalone but not in 3ds max. Hopefully i did everything right. In Standalone Light shines through, in 3ds not. Material looks simply Amazing! Tried it with a Ring - it look 1:1 lice cnc cutted Wax. Perfect :-)
cfrank78 Hi,
Apparently, there has been mess up with the scale conversion with octane and max simply because of unit setup.
But the solution is simple. You need to lower the Scale of the Scattering Medium down to 50-100 ish..
It will always vary depending on your scene scale...
You can see a very quick messy preview render from max as a proof as well :)
I also added two hdri environment, daylight lighting renders in Max.
Posted: Thu Dec 06, 2012 2:38 am
by RayTracey
Nice renders! You will enjoy this feature I think: http://render.otoy.com/forum/viewtopic.php?f=6&t=25747 ;)
Posted: Thu Dec 06, 2012 2:43 am
by oguzbir
RayTracey wrote:Nice renders! You will enjoy this feature I think: http://render.otoy.com/forum/viewtopic.php?f=6&t=25747 ;)
Thank you..
Oh my..
This is the best of all....
You will again make us refresh the forum few times a day..
Thank you for that! :D
Posted: Thu Dec 06, 2012 12:21 pm
by cfrank78
You were completely right - it was the scale of teh scattering.
Oh my i have to learn. So much :-P Materials in Octane are mighty - but no one click solution like i was used to :-)
Posted: Thu Dec 06, 2012 6:43 pm
by 3form
Just used on some candels works well in max. will post in gallery. ;)
