Page 1 of 2
Problem in exporting to animation.
Posted: Fri Sep 28, 2012 11:41 pm
by kaskudo
guys,
I bought the octane yesterday and am having trouble to render a simple animation.
Appears the following error message ..Image
I do not know what else to do ..
Could you help me?
Re: Problem in exporting to animation.
Posted: Sat Sep 29, 2012 2:06 am
by kavorka
unfortunately, you cannot use spaces in the exporter. Get a filename with no spaces and you will be okay. The exporter was originally made when Octane didnt allow spaces, so thats why its there, just hasnt been updated yet.
Posted: Sat Sep 29, 2012 8:59 am
by DayVids
You may find this helpful, I was experiencing some problems as well, and managed to get them resolved.
http://render.otoy.com/forum/viewtopic. ... 1&start=10
Also, if you're doing an animation there is a line you need to change in the 1.20 exporter.
http://render.otoy.com/forum/viewtopic.php?f=32&t=23546
Hope this helps with your problem...
Posted: Mon Oct 01, 2012 4:11 am
by kaskudo
Thank you.
I will read this information and test again here to export my animation.
After I explain here if it worked or not.
Posted: Tue Oct 02, 2012 12:33 am
by kaskudo
Guys.
I have no spaces in the path that I put in my project, I have strange symbols in my project and yet does not work nor the export of an animation.
I'm using the plugin .. 1:19
Is there a more updated?
I'm using Blender 2.63 (r46461: 46487M)
I would like a solution and can not do anything, I need to surrender much of a job.
Posted: Tue Oct 02, 2012 5:42 am
by DayVids
Can you copy and paste the blender info panel from when you have the error?
Also, 1.20 is found here-http://www.refractivesoftware.com/forum ... 373#p96373, but remember that there is a change to the script that you have to do, per my threads I pointed you to.
PM me if you have no additional luck.
What does the python drive info show for your location that you're saving to?
Dave
Posted: Tue Oct 16, 2012 4:02 am
by kaskudo
Here is my problem.
Traceback (most recent call last):
File "C:\Program Files\Blender Foundation\Blender\2.64\scripts\addons\octanerender\engine.py", line 65, in render
error('Image output directory is invalid or contains spaces "%s" ("%s")' % (octane_render.path,animPath))
File "C:\Program Files\Blender Foundation\Blender\2.64\scripts\addons\octanerender\utils.py", line 81, in error
raise Exception("Octane plug-in: "+error)
Exception: Octane plug-in: Image output directory is invalid or contains spaces "C:\Users\Douglas\Desktop\OCTANE_RENDER\" ("C:\Program Files\Blender Foundation\Blender")
Thanks..
Posted: Tue Oct 16, 2012 12:04 pm
by orion_uk
I just kept getting this..
I changed my render/image output directory to C:\RENDERS
Saved my Blender scene, quit Blender and re-started Blender and its running fine now :)
Well, kind of!
Render animation renders the first frame fine. I click render animation, Octane starts up, renders first frame,closes but does NOT start up again for the second frame!
Posted: Tue Oct 16, 2012 1:47 pm
by orion_uk
Never mind, matej showed me a solution...thanks matej ;)
This URL here
Posted: Sun Jan 27, 2013 7:24 pm
by lakris
Im having the same problem(mine says line 65), and none of the above links/help is working :|
I hope the Blender official plugin is coming soon.
