OctaneRender® for Maya® beta 2.58c [OBSOLETE]
Posted: Fri Jul 13, 2012 3:24 pm
Refractive Software®/Otoy® is proud to announce the availability of a first version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
Just like OctaneRender™ Standalone, the Maya® plugin product also needs an additional OctaneLive license and be activated on a machine.
This has to be done in the plugin interface panel in Maya, and is covered in the included PDF manual.
It can only be done after an OctaneRender™ Standalone license is already activated on the machine in question.
BUG FIXES SINCE LAST RELEASE:
Next version HERE.
Yours,
The OctaneRender™ Team.
OCTANELIVE
- Fixed one more crash bug.
- Fixed bug when Attribute Editor "Inline" value not appeared immidiately after disconnecting of Octane Node from it.
- Minor fixes...
- Added "Opacity" attribute to Octane Light node.
- Now it is able to render without SunSky node present in scene. In this case the black environment will be set as default.
- Added "batch command render mode" support. It is experimental so far, so you may test it. See command line help by:
<Maya install path>/bin/render -renderer octane -help
Next version HERE.
Yours,
