C4D r11 camera problem with 11c
Posted: Thu Jun 28, 2012 10:22 pm
by Daveyay
Hi
I have C4d r11 and using exporter 11c to build 2.58. All fine except when I export the camera from any model I get an error, the heading of which reads:
There was an error parsing the command-line arguments:
Couldn't find match for argument Argument: 0
I can post the full message if necessary
I've tried changing units and so on, but no luck. And the export is always successful without the camera. Any thoughts please?
Re: C4D r11 camera problem with 11c
Posted: Fri Jun 29, 2012 10:00 pm
by abstrax
Daveyay wrote:Hi
Could you post a screenshot of the C4D console window? It should show the command line that was used to open Octane.
Marcus
Posted: Sat Jun 30, 2012 8:08 am
by bepeg4d
abstrax wrote:Thanks,
Marcus
oh man, are you back?
i can't believe
this is the best birthday present that i could have (one day before to tell the truth)
ciao beppe
Posted: Sat Jun 30, 2012 5:48 pm
by niuq.cam
Marcus? This is a joke? You're back in the team? Can we have some clarifications? I hope this is real.
Posted: Mon Jul 02, 2012 12:40 pm
by Daveyay
Marcus,
Thank you. No need to post the screenshot, I checked it today and yes I had the wrong path set.
All fine now, Thanks!!
David
Posted: Wed Sep 12, 2012 8:41 am
by AndersBackman
I have the same problem. Octane works fine when exporting from C4D except when I check "Export Camera". When I try to export the camera, then Octane opens with this popup.
USAGE:
dummy program name [-m <string>] [-r <filename>] [-l <filename>] [-n
<filename>] [--imager-exposure <float>]
[--daylight-sundir-z <float>] [--daylight-sundir-y
<float>] [--daylight-sundir-x <float>]
[--cam-aperture <float>] [--cam-focaldepth <float>]
[--cam-fov <float>] [--cam-motion-up-z <float>]
[--cam-motion-up-y <float>] [--cam-motion-up-x
<float>] [--cam-motion-target-z <float>]
[--cam-motion-target-y <float>]
[--cam-motion-target-x <float>] [--cam-motion-pos-z
<float>] [--cam-motion-pos-y <float>]
[--cam-motion-pos-x <float>] [--cam-up-z <float>]
[--cam-up-y <float>] [--cam-up-x <float>]
[--cam-target-z <float>] [--cam-target-y <float>]
[--cam-target-x <float>] [--cam-pos-z <float>]
[--cam-pos-y <float>] [--cam-pos-x <float>] [-q] [-g
<int>] ... [-s <int>] [-o <filename>]
[--film-height <int>] [--film-width <int>] [-e] [--]
[--version] [-h] <filename>
Where:
-m <string>, --mesh-node <string>
Name of meshnode to render
-r <filename>, --relink-meshnode <filename>
Name of OBJ mesh file to relink rendered meshnoded with
-l <filename>, --link-meshnode <filename>
Name of OBJ mesh file to link after startup
-n <filename>, --new <filename>
Create a new OCS project file from given command line arguments
Imager Exposure Amount
Daylight Sun Direction Vector Z Component
--daylight-sundir-y <float>
Daylight Sun Direction Vector Y Component
Daylight Sun Direction Vector X Component
Camera Aperture Radius
Camera Focal Depth
--cam-fov <float>
Camera FOV (degrees)
Camera Up Motion 2nd Vector Z Component
Camera Up Motion 2nd Vector Y Component
--cam-motion-up-x <float>
Camera Up Motion 2nd Vector X Component
Camera Target Motion 2nd Position Z Component
Camera Target Motion 2nd Position Y Component
Camera Target Motion 2nd Position X Component
--cam-motion-pos-z <float>
Camera Motion 2nd Position Z Component
Camera Motion 2nd Position Y Component
Camera Motion 2nd Position X Component
--cam-up-z <float>
Camera Up Vector Z Component
--cam-up-y <float>
Camera Up Vector Y Component
--cam-up-x <float>
Camera Up Vector X Component
Camera Target Position Z Component
Camera Target Position Y Component
Camera Target Position X Component
--cam-pos-z <float>
Camera Position Z Component
--cam-pos-y <float>
Camera Position Y Component
--cam-pos-x <float>
Camera Position X Component
-q, --quiet
Start Application without splash and minimized window
-g <int>, --gpu <int> (accepted multiple times)
add GPU device to use for rendering (0 = first)
-s <int>, --samples <int>
Maximum number of samples per pixel (maxsamples)
-o <filename>, --output-png <filename>
Output PNG imagefile when maxsamples is reached
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
Close the application when rendering is done
--, --ignore_rest
Ignores the rest of the labeled arguments following this flag.
--version
Displays version information and exits.
-h, --help
Displays usage information and exits.
<filename>
.OCS Project scene file
Octane Render
The C4D console says this:
"C:\Program Files\Octane\octane.exe" -n "C:\Users\Anders\Desktop\OctaneTest\RaceBoat_02.ocs" -m RaceBoat_02 -l "C:\Users\Anders\Desktop\OctaneTest\RaceBoat_02.obj" --film-width 1280 --film-height 544 --cam-pos-x 42.350042 --cam-pos-y 206.99491 --cam-pos-z -156.65632 --cam-target-x -115.66944 --cam-target-y 115.64547 --cam-target-z 32.728856 --cam-up-x -1.0729283e-008 --cam-up-y 1 --cam-up-z -8.9523148e-009 --cam-fov 90 --cam-lensshift-right 0 --cam-lensshift-up -0
Can't see anything wrong with my paths.
Daveyay - what path set did you change?
Posted: Wed Sep 12, 2012 9:11 am
by face
The problem is the first parameter:
-n will create a new ocs-file
It should be like this:
octane.exe -m test.obj -r "G:\Octane\ProjectA\test.obj" --cam-up-x -0.228925 --cam-up-y 0.918097 --cam-up-z -0.323561 --cam-target-x 1.77636e-015 --cam-target-y -4.44089e-015 --cam-target-z 0 --cam-pos-x 10.6582 --cam-pos-y 7.96666 --cam-pos-z 15.0643 --cam-fov 53.638 --cam-aperture 1 --cam-focaldepth 5 --imager-exposure 1 "G:\Octane\ProjectA\test.ocs"
face
Posted: Wed Sep 12, 2012 10:03 am
by AndersBackman
Ok. So now I've gotten the exporter to spit this out (which seems to be about the same as you suggested):
"C:\Program Files\Octane\octane.exe" -m RaceBoat_02 -r "C:\Users\Anders\Desktop\OctaneTest\RaceBoat_02.obj" --cam-pos-x 42.350042 --cam-pos-y 206.99491 --cam-pos-z -156.65632 --cam-target-x -115.66944 --cam-target-y 115.64547 --cam-target-z 32.728856 --cam-up-x -1.0729283e-008 --cam-up-y 1 --cam-up-z -8.9523148e-009 --cam-fov 90 --cam-lensshift-right 0 --cam-lensshift-up -0 "C:\Users\Anders\Desktop\OctaneTest\RaceBoat_02.ocs"
Still the same error message when entering Octane though. Unless I deselect camera export.
Posted: Wed Sep 12, 2012 10:12 am
by face
The -m RaceBoat_02 should be -m RaceBoat_02.obj.
face
Posted: Wed Sep 12, 2012 11:34 am
by abstrax
Hi Anders and Face,
If the mesh node must be named like the OBJ file, then this is a recent change in Octane. I need to look at it tomorrow. -m should specify only the mesh node to render, which can be named anything. The C4D exporter always omitted the .obj suffix which was fine until now.
I think the problem is the parameter "--cam-lensshift-up -0". I guess, for some reason the command line parser of Octane reads "-0" as an argument and not as number/value.
You can try this by slightly changing the "Film Offset Y" in the C4D camera you are exporting. If it works, then this was the problem.
Cheers,
Marcus
