polygons show in rendering
Posted: Tue Mar 20, 2012 1:32 pm
by gueoct
Anybody seen this before? is this a memory issue?
Re: polygons show in rendering
Posted: Tue Mar 20, 2012 2:28 pm
by t_3
no image? ;)
Posted: Thu Mar 22, 2012 10:10 am
by gueoct
Sorry; here we go again:
Posted: Thu Mar 22, 2012 10:35 am
by t_3
quite sure not a memory issue. can't really tell from the image, but the first thing to look for would be imo the scene scale. this is often mismatched while import objects, and octane is showing artifacts on kilometers large objects. you may also try to lower ray_epsilon and see if this helps...
Posted: Thu Mar 22, 2012 1:23 pm
by gueoct
rayepsilon is at 0,0.
scale is 1200 cm x 600 cm...
Posted: Thu Mar 22, 2012 1:40 pm
by t_3
gueoct wrote:rayepsilon is at 0,0.
can you upload the scene? would be easier to check what could be the problem...
Posted: Thu Mar 22, 2012 3:50 pm
by be_fast
You should make reset Xform and if it does not halp just make a box with similar scale and attach your object to this new-created box. Then go to elements in the editable poly and delete box element
Hope its gona work
