Page 10 of 29
Re: OctaneRender 2020 for DAZ Studio [TEST and STABLE]
Posted: Sun Feb 23, 2020 9:23 am
by rajib
rajib wrote:Isotemod wrote:
Before loading one of these scenes load a prop into a blank scene after opening Daz and open the viewport so it begins rendering(no materials needed).
Then close the viewport and load your scene as normal.
For some reason the plugin gets stuck on creating geometry for the first time on some saved scenes.
This workaround has not failed me so far.
Thanks for sharing your workaround. Will give it a try.
Thanks Isotemod.
The workaround worked. One of my scenes that always got stuck in the building geometry and the running yellow bar loaded and rendered fine after I tried your workaround.
Cheers,
Rajib
Posted: Sun Feb 23, 2020 9:29 am
by rajib
face_off wrote:rajib wrote:Hi Paul,
I have a request to add a missing feature : Visible Environment. Please take a look at
viewtopic.php?f=44&t=72407&p=377687#p377687. See if you add this for us. It is present in the 2019.1.5 Standalone as well as in other plugins.
Regards,
Rajib
This is on the TODO list.
Btw. Paul, regarding Visible Environment, may I know when are you planning to get it done ? It has been available on the standalone and other plugins for some time now.
Posted: Mon Feb 24, 2020 10:51 pm
by face_off
Adding support for the Visible Environment is not an easy thing to add within the constraints of the current codebase, and would need to be done as a much larger body of work allow all the new Octane features to be added to the plugin. So I wouldn't expect this to be done in the near future.
Posted: Thu Feb 27, 2020 5:22 am
by face_off
Hun73rdk_1 wrote:New Beta update of daz studio brakes something in octane it wont unload memory anymore have to kill daz every time now
I am not usre what you mean by this. Which version of the plugin and DAZStudio are you running? What do you mean by "unload memory"?
Posted: Fri Feb 28, 2020 8:09 pm
by Laticis
rajib wrote:
Hi Laticis,
I think that GoZ like feature will be the Octane > System (tab) -> Export -> Complete Scene. It is manual and does not automatically provide a back and forth way of doing things like ZBrush does with GoZ. But at least one can export from Daz and import the scene in Octane Standalone and tweak and render it there. Things that probably may not work is Daz Dynamic hair, etc but at least the LAMH Hair OBJs will show up correctly. In terms of importing it back after tweaking (Octane > System (tab) -> Import -> Complete Scene) I am not too sure what will happen to the Material nodes that the Daz plugin does not support that Octane Standalone does. I am never tried importing but have done export scene and open it in the standalone and it does work. Will probably need to do some RnD.
Regards,
Rajib
Hi Rajib,
Thanks heaps for your feedback
Ideally, I would love to never leave DAZ Studio to render with Octane's full functionality.
Cheers Ady
Posted: Sat Feb 29, 2020 8:35 am
by rajib
Laticis wrote:rajib wrote:
Hi Laticis,
Regards,
Rajib
Hi Rajib,
Cheers Ady
Hi Ady,
You are most welcome. I too would love to be able to do that
. GoZ is so easy and seamless.
Take care,
Rajib
Posted: Sat Feb 29, 2020 8:41 am
by rajib
Hi Paul,
Can we have the 2020.1 RC1 plugin ? I would like to test and see if the issue like the OOC memory, UV edge in SSS, etc. issues are fixed. I am desperately looking forward to the OOC issue being resolved because rendering any heavy scene is just about impossible in the current versions and a lot of my scenes are waiting to be rendered.
Thanks and regards,
Rajib
Posted: Sat Feb 29, 2020 12:20 pm
by rajib
Thanks and regards,
Rajib
I tested a scene that always gave a memory error with OOC in the both the plugin and standalone with 2018.x / 2019.x and 2020.x up to XB3 and it finally rendered in the Standalone 2020.1 RC1
! So whatever they did this time to the OOC code seems to have fixed the issue. Looking forward to the plugin release now. Many many scenes to render that I have not been able to render for a long while.
- 2020.1 RC1 Standalone with OOC memory being used
Posted: Sat Feb 29, 2020 8:21 pm
by parkwaychris
I’ve had the same issue, Rajib. Thanks for the update. Here’s to hoping we can enjoy RTX and OOC very soon.
Posted: Sun Mar 01, 2020 2:31 am
by face_off
Standalone RC2 is out, so I will do a plugin build with RC2 once the API is available.
