Page 10 of 24
Re: Cinema 4D version 4.05-R2 (Latest stable) 15.08.2019
Posted: Mon Sep 02, 2019 10:36 am
by aoktar
marshalartist wrote:I did explain that without the texture managers that the scenes open instantly, but with the managers docked they take forever or crash. We only have C4D octane scenes not standard C4D scenes, I don't see how this is relevant though, it all worked fine in R4.01. Thank you for looking into this though, it is not much of a hindrance now we know what it is.
Please contact me by PM if you wish me look into deeper. I'll need some scenes and more information.
Posted: Tue Sep 03, 2019 4:26 am
by divasoft
Hi, Distribution on surface look regular like rows. can I do something to make distribution of clones is not regular?
Posted: Tue Sep 03, 2019 7:53 pm
by TonyBoy
It works off the polygons. With the Forester version you can use "polygon area" instead of vector or 'center'. Maybe a solution there.
Posted: Tue Sep 03, 2019 10:42 pm
by frankmci
Does a Random Effector driving the X and Z of your Scatter objects not work in your situation?
Re: Cinema 4D version 4.05 (Latest stable) 12.08.2019
Posted: Wed Sep 04, 2019 2:24 am
by kaisdaddy
aoktar wrote:
fractaledvisions wrote:Cinema4D R20 won't open after I installed this. Just hangs at 5% CPU usage in the task manager and never opens. Was hoping this would fix endless crashes on 4.04. Guess not.
Have you deleted other versions of plugin dlls? There's R21 build and keeps locking the R20 plugin if you keep it.
I just installed C4D R21 today and downloaded the latest stable version of Octane just now but I don't see an r21 lib file when I extract the archive. Please advise, as I need to get it up and running asap. Thanks!
Posted: Thu Sep 05, 2019 1:46 pm
by divasoft
frankmci wrote:Does a Random Effector driving the X and Z of your Scatter objects not work in your situation?
Random effector will not scatter clones through plane with texture displasion. if i use it clones will be "fly" near ground
Posted: Thu Sep 05, 2019 3:03 pm
by moebius
R21
Node Editor navigation stops working after a couple of Clicks
Can't connect Nodes anymore, just push around the whole workplane
sorry, if someone postet it earlyer
Posted: Thu Sep 05, 2019 7:54 pm
by atome451
moebius wrote:R21
Thanks for the information. Now, i know i'm not alone in this case. ;)
Re: Cinema 4D version 4.05-R3 (V4 stable) 06.09.2019
Posted: Thu Sep 05, 2019 10:48 pm
by aoktar
Updated the builds with better R21 support. Enjoy it!
Posted: Fri Sep 06, 2019 11:35 am
by marshalartist
Just tried the new version with R21, all seems to be working great. The Octane Texture Manager still causes C4D to stall if it is docked in the interface and it is accessing a large directory of texture files. It's great to be able to use R21 straight away without having to wait for Octane compatibility, thanks for that
