Page 10 of 15
Re: OctaneRender® for ArchiCAD 2.12.1 [TEST]
Posted: Thu Nov 13, 2014 7:34 am
by face_off
A small amendment/fix to the above test build:
2.12.1.27
- Fixed issue where grass and scatter instances were not being placed on thin triangle polygons from round ArchiCAD Mesh objects
- Fixed issue where the "Loading Scene into Octane...." status window was not being displayed
- The "You can only write to an ABC file which is not currently in use..." error message is now displayed prior to calculating grass blades
- Added CSV button to the Materials tab which will produce a CSV file containing all the transforms for the Objects that are the same type as the selected Object
- Fixed issue where texturemaps were being reported as missing if they were on a folder mapped a drive letter
Download Links
Download the plugin from the following links:
- OctaneRender for ArchiCAD 18 2.12.1.27 (64 bit)
- OctaneRender for ArchiCAD 17 2.12.1.27 (64 bit)
- OctaneRender for ArchiCAD 16 2.12.1.27 (64 bit)
Posted: Thu Nov 13, 2014 7:46 am
by rappet
Hi Paul,
That is a quick fix! Thanx.
Glad you could fix triangle polygons from round mesh.
Cheers,
Posted: Fri Nov 14, 2014 3:09 am
by face_off
A small amendment/fix to the above test build.
2.12.1.28
- Fixed issue where generating scatters and grass was not working correctly for ArchiCAD "holes"
- Long Proxy and Scatter filenames (in the Geometry Proxy Details dialog) now scroll
Download Links
- OctaneRender for ArchiCAD 18 2.12.1.28 (64 bit)
- OctaneRender for ArchiCAD 17 2.12.1.28 (64 bit)
- OctaneRender for ArchiCAD 16 2.12.1.28 (64 bit)
Posted: Fri Nov 14, 2014 10:52 am
by rappet
face_off wrote:A small amendment/fix to the above test build.
2.12.1.28
Download Links
Hi Paul,
When rendering animation and having 'rebuild scene.." not on.. it does load the scene anyway for every frame?!
greetings,
Posted: Sun Nov 16, 2014 2:05 am
by face_off
Hi Jeroen. "Rebuild Scene" should not effect rendering animations - it only effects if the scene is reloaded when you change the currently selected AC view. If you have the Viewport port (or have closed the Viewport but left the Setup window open), rendering to the Photorenderer will pick up the scene currently loaded in the video card - so will not load the animated geometry. Close the Setup window prior to do a Photorender to cause the scene to be reloaded.
Does that answer your question?
Posted: Mon Nov 17, 2014 2:56 am
by face_off
2.12.1.29
- Fixed issue introduced in 2.12.1.28 preventing the Photorenderer from opening when "Fast Cache" was enabled
- Includes the changes in 2.12.1.25 - 2.12.1.28
Posted: Wed Nov 19, 2014 6:18 am
by face_off
2.13.0.30
- Compiled with 2.13. See the Octane Standalone 2.13 release notes for important changes made in this release
- IMPORTANT: Requires Cuda driver 344.x or later
- Photorendering now displays the current and max samples, and the elapsed to estimated total time
- Add Lock Aspect Ratio checkbox to the Resolution node info. This defaults to OFF each time ArchiCAD is started
Re: OctaneRender® for ArchiCAD 2.13 [TEST]
Posted: Sun Nov 23, 2014 11:39 pm
by ArchPrime
Hi Paul - for me, number of samples is incorrectly reported in progress indicator dialog (or my selection is actually being ignored or overridden by Octane somehow). If I select 800 max samples in kernel, render dialog reports the total samples as 300.
Perhaps that is behind the reported speed increase? :)
Posted: Mon Nov 24, 2014 4:25 am
by face_off
The max samples setting is being displayed correctly. Perhaps you have a different rendertarget set in the View combo box in the Photorender settings?
Posted: Tue Nov 25, 2014 11:58 pm
by face_off
2.13.0.31
- Slightly changed the Photorendering status display format
- Keeping texturemap filenames unique in the Export Assets function is now optional. If you answer Yes to this, all texturemap filenames will be changed to ensure the same filename from different directories are not merged.
- Added ability to load and save materials from the Octane Standalone localDb (.orbx format).
