Page 10 of 14
Re: MAX2Octane exporter for max 2010+
Posted: Thu Oct 28, 2010 2:37 am
by criko3d
Hi kilad, look i have this problem, i set up my scene, export for still frame and everything runs just fine..., but when i render animations, it crashes both octane and 3ds max, i´m using 3ds max 2010 x64, last version of octane, and last version of max 2 octane... any ideas? this is the message i´ve got:
There was an error parsing the command-line arguments:
Couldn't find match for argument Argument: C:\Users\criko\Documents\\TEST.ocs
USAGE:
dummy program name [-m <string>] [-r <filename>] [-l <filename>] [-n
<filename>] [--imager-exposure <float>]
[--daylight-sundir-z <float>] [--daylight-sundir-y
<float>] [--daylight-sundir-x <float>]
[--cam-aperture <float>] [--cam-focaldepth <float>]
[--cam-fov <float>] [--cam-motion-up-z <float>]
[--cam-motion-up-y <float>] [--cam-motion-up-x
<float>] [--cam-motion-target-z <float>]
[--cam-motion-target-y <float>]
[--cam-motion-target-x <float>] [--cam-motion-pos-z
<float>] [--cam-motion-pos-y <float>]
[--cam-motion-pos-x <float>] [--cam-up-z <float>]
[--cam-up-y <float>] [--cam-up-x <float>]
[--cam-target-z <float>] [--cam-target-y <float>]
[--cam-target-x <float>] [--cam-pos-z <float>]
[--cam-pos-y <float>] [--cam-pos-x <float>] [-q] [-g
<int>] ... [-s <int>] [-o <filename>]
[--film-height <int>] [--film-width <int>] [-e] [--]
[--version] [-h] <filename>
Where:
-m <string>, --mesh-node <string>
Name of meshnode to render
-r <filename>, --relink-meshnode <filename>
Name of OBJ mesh file to relink rendered meshnoded with
-l <filename>, --link-meshnode <filename>
Name of OBJ mesh file to link after startup
-n <filename>, --new <filename>
Create a new OCS project file from given command line arguments
Imager Exposure Amount
Daylight Sun Direction Vector Z Component
--daylight-sundir-y <float>
Daylight Sun Direction Vector Y Component
Daylight Sun Direction Vector X Component
Camera Aperture Radius
Camera Focal Depth
--cam-fov <float>
Camera FOV (degrees)
Camera Up Motion 2nd Vector Z Component
Camera Up Motion 2nd Vector Y Component
--cam-motion-up-x <float>
Camera Up Motion 2nd Vector X Component
Camera Target Motion 2nd Position Z Component
Camera Target Motion 2nd Position Y Component
Camera Target Motion 2nd Position X Component
--cam-motion-pos-z <float>
Camera Motion 2nd Position Z Component
Camera Motion 2nd Position Y Component
Camera Motion 2nd Position X Component
--cam-up-z <float>
Camera Up Vector Z Component
--cam-up-y <float>
Camera Up Vector Y Component
--cam-up-x <float>
Camera Up Vector X Component
Camera Target Position Z Component
Camera Target Position Y Component
Camera Target Position X Component
--cam-pos-z <float>
Camera Position Z Component
--cam-pos-y <float>
Camera Position Y Component
--cam-pos-x <float>
Camera Position X Component
-q, --quiet
Start Application without splash and minimized window
-g <int>, --gpu <int> (accepted multiple times)
add GPU device to use for rendering (0 = first)
-s <int>, --samples <int>
Maximum number of samples per pixel (maxsamples)
-o <filename>, --output-png <filename>
Output PNG imagefile when maxsamples is reached
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
Close the application when rendering is done
--, --ignore_rest
Ignores the rest of the labeled arguments following this flag.
--version
Displays version information and exits.
-h, --help
Displays usage information and exits.
<filename>
.OCS Project scene file
Octane Render
Posted: Thu Oct 28, 2010 6:48 am
by face
I see a double \ for the TEST.ocs.
That should be the error...
face
Posted: Thu Oct 28, 2010 9:24 am
by kilaD
Yes, Face is probably right. Make a new folder and press new project.
Posted: Fri Oct 29, 2010 6:42 pm
by ttaberna
Hi
I need help
I have this message everytime I try to use the script:
Couldn't read argument value from string '-267,179' Argument: (--cam-pos-x)
USAGE:
Where:
     Camera Focal Depth
   --cam-fov <float>
   --cam-up-z <float>
   --cam-up-y <float>
   --cam-up-x <float>
   --cam-pos-z <float>
   --cam-pos-y <float>
   --cam-pos-x <float>
   -q,  --quiet
   --film-height <int>
     Film height
   --film-width <int>
     Film width
   -e,  --exit
   --,  --ignore_rest
   --version
   -h,  --help
   <filename>
   Octane Render
If anyone could help please
Thank you
Posted: Fri Oct 29, 2010 7:51 pm
by kilaD
Hey yes it's the comma, should be a period. It's probably because of your language which is...I guess Spanish?
Anyway i find it strange that it is possible at all. I'll write a small fix!
Posted: Sat Oct 30, 2010 6:51 am
by criko3d
hi, already checked the double // but still get errors, here i paste!
Couldn't find match for argument Argument: C:\Users\criko\Desktop\test\test.ocs
USAGE:
Where:
Camera Focal Depth
--cam-fov <float>
--cam-up-z <float>
--cam-up-y <float>
--cam-up-x <float>
--cam-pos-z <float>
--cam-pos-y <float>
--cam-pos-x <float>
-q, --quiet
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
--, --ignore_rest
--version
-h, --help
<filename>
Octane Render
HOPE YOU CAN HELP OUT WITH THIS!!! :twisted:
Posted: Sun Oct 31, 2010 2:30 pm
by ttaberna
:D Thanx killaD I'll wait for that fix...
And yes I'm from Spain.
Posted: Tue Nov 02, 2010 8:49 pm
by criko3d
hi can anybody help me out with the render animation problem i posted upside?, thanksss! please!
Posted: Tue Nov 02, 2010 11:32 pm
by kilaD
Try it again and copy&paste the message in the listener here.
F11 to open the maxscript listener in 3dsmax. Copy the message after you get the error
k
Posted: Wed Nov 03, 2010 12:12 am
by kilaD
UPDATE: Max2Octane 1.022g
@ttaberna: Download the latest script Max2Octane 1.022g. Hopefully 1.022g should fix your errors with commas.
http://www.refractivesoftware.com/forum ... hp?id=6758
good luck
k
