Page 10 of 11
Re: OctaneRender® for 3ds max® v1.0 beta 2.58c[CURRENT]
Posted: Tue May 29, 2012 7:13 am
by gabrielefx
***Merging material issue***
Hi Karba:
when I merge Max models already texturized with Octane for Max and I select "use scene material" then in my scene I found duplicated materials.
Posted: Tue May 29, 2012 5:27 pm
by Philipp1980
Did you try to use Standalone version? Does it have such problem?
I tried the Standalone version and all three cards worked fine without crashing also on high resolutions (because of time I only tested it with the chess-scene).
I am now waiting for my fourth card and then I will do some more tests. Maybe I can figure out more precisly when the crashes exactly occure.
Is there a general limitation of resolution size except the limit set by the size of the card-memory?
I have a customer that first wanted an interior rendering only for a catalogue (that's why i have choosen Octane) and now he also wants to use
it for a construction sign with the size of 3,5m and as high dpi as possible...
Posted: Tue May 29, 2012 9:10 pm
by petermax
*** please add motion blur - this is essential for animation!!
I don't mean camera motion blur... I mean object motion blur!
Posted: Tue May 29, 2012 10:56 pm
by Karba
gabrielefx wrote:***Merging material issue***
Hi Karba:
Hm, I will check it.
Posted: Tue May 29, 2012 10:57 pm
by Karba
At this moment limitation is only for interactive render. (It will be removed in next version 2.58d).
For final render there is not any limitation.
Posted: Tue May 29, 2012 10:59 pm
by Karba
petermax wrote:*** please add motion blur - this is essential for animation!!
It will be ready after instancing support (only for object moving, not for a object form animation)
Posted: Thu May 31, 2012 5:58 am
by Sergey_Baskakov
Здравствуйте!
Я оплатил лицензию на Octane для 3d-max, но у меня возникли проблемы с активацией. Установил все правильно и Max увидел OctaneRender. На сайте в своем профиле я получил User ID и Password, но при вводе их в 3dMax, появляется окно с запросом активации для Standalone версии.
Для иллюстрации проблемы сделал скриншот.
подскажите пожалуйста, как эта проблема решается?
Posted: Thu May 31, 2012 6:37 am
by Karba
Sergey_Baskakov wrote:Здравствуйте!
Требуется две пары логин/пароль. Одна для standalone, другая для плагина. Соответсвенно обе лицензии надо приобрести.
Posted: Thu May 31, 2012 6:50 am
by Sergey_Baskakov
Понятно... Видимо я невнимательно читал и упустил этот момент... моя ошибка
... А можно ли поменять сейчас тип лицензии на standalone, чтобы не доплачивать ещё 99 евро?
Posted: Thu May 31, 2012 6:54 am
by Karba
Sergey_Baskakov wrote:Понятно... Видимо я невнимательно читал и упустил этот момент... моя ошибка
Обратитесь в тех поддержку, я этим не занимаюсь. Но если вы работаете в 3dsmax, рекомендую докупить standalone, так как сам по себе standalone без плагина довольно неудобен при работе с 3dsmax.
