Page 9 of 12
Re: Cinema4D version 2020.2.3-R4 (Latest stable) 15.05.2021
Posted: Fri May 21, 2021 2:54 am
by afups
octane hair material can't use mat layer !!!. can't mix !! When mat.layer opacity is zero ,The color will turn to solid black!!!
Posted: Fri May 21, 2021 1:10 pm
by 14bmwc780nike
aoktar wrote:
14bmwc780nike wrote:Under R21 (updated to latest with current nVidia studio drivers) all lights built in an existing studio seem to have lost their intensity. Had to revert back to R3.
Would mind to do a better feedback? Area lights without Light tag will have a different intensity. It's not absolutely adviced to use without tags, because of don't having explicit control for light parameters.
Scene does use Octane light tags. I can't share the scene publicly.
Update - checked R5 and still having the same issues. I did DM a link to my icloud drive to the file. If I remove the images from the Octane light tags, the scene lights do work but of course not in the desired fashion.
R4 Render
R3 Render
Posted: Sat May 22, 2021 9:30 am
by aoktar
R4 Render
R3 Render
If you convert Bitmaps in light tags to ImageTexture, that will be fix it. I'm looking for what changed and how to fix it
Re: Cinema4D version 2020.2.3-R6 (Latest stable) 22.05.2021
Posted: Sat May 22, 2021 12:01 pm
by aoktar
Released a hotfix build for some issues. Links are on first page, download links will be updated soon.
Posted: Sat May 22, 2021 3:13 pm
by thanulee
Thanks for the R6 update. Cant save file if there is no folder. Is that a bug?
Posted: Mon May 24, 2021 10:10 am
by wrapthereal66
Thanks for the update! 2 things that i found :
1/ octane crash with a background object from c4D
2 / solo node is working just when you add a transform node to it!
Posted: Mon May 24, 2021 6:00 pm
by thanulee
I get this freeze in viewport when i try to move a cloner with splines. Object tag>render as hair
It seems to recalculate everything even with a viewport pan. Is there a way to fix/optimize this behavior?
See issue here: https://www.dropbox.com/s/wcsg7xwscd9yq ... .webm?dl=0
Posted: Tue May 25, 2021 6:41 am
by hazenkind
thanulee wrote:Hi,
Same here with XParticle and xpTrail and render as hair.
Posted: Tue May 25, 2021 5:58 pm
by thanulee
hazenkind wrote:
thanulee wrote:Hi,
Same here too. Freezes with render as hair in xp trail
Posted: Tue May 25, 2021 6:58 pm
by 14bmwc780nike
aoktar wrote:If you convert Bitmaps in light tags to ImageTexture, that will be fix it. I'm looking for what changed and how to fix it
Thank you for the update!
