Page 9 of 18
Re: Version 4.0-RC7-R3 (Latest release candidate) 07.11.2018
Posted: Wed Nov 07, 2018 8:34 pm
by thanulee
U rock Ahmet!
Posted: Thu Nov 08, 2018 2:31 am
by aoktar
thanulee wrote:U rock Ahmet!
thanks!
Posted: Thu Nov 08, 2018 7:57 am
by pxlntwrk
aoktar wrote:
- New parameter to use the denoised beauty in main buffer without enabling the render passes
this plugin becomes more and more smart over time.
Thanks for that !
Posted: Thu Nov 08, 2018 9:06 am
by Aleksei
Hi!
I have a suggestion: it would be more user friendly if plugin will open page in a
default browser instead of the
standard system browser (Internet Explorer).
Posted: Thu Nov 08, 2018 9:41 am
by LOVEXMEDIA
Aleksei wrote:Hi!
Yeah this would be great! Not sure how easily it would be to implement but in the future it would be nice to see something this sleek with each new update or revision.
Posted: Thu Nov 08, 2018 9:44 am
by Aleksei
LOVEXMEDIA, it is already implemented. But I was talking about browser.
Posted: Thu Nov 08, 2018 11:01 am
by aoktar
Aleksei wrote:Hi!
I'm aware of the problem. But couldn't find a way yet, looking for that.
And as you said, version update system is available since previous build. You can call it from LV's help menu and change automatic checking. If you wish.
Posted: Thu Nov 08, 2018 11:35 am
by BCres
aoktar wrote:lucioing wrote:aoktar wrote:New build available, enjoy it!
Ahmet the great!
Thank you for your hard and finest work! You are, as always, the best!
What about the denoiser pas? What do you mean?
"New parameter to use the denoised beauty in main buffer without enabling the render passes"
Thank you again
L.
This is new option to use denoised beauty in main buffer. Even without need of activating the denoising from camera imagers. Thanks much!
Just tested. This is genius! The biggest obstacle I had using the new denoiser was C4D's insistence on saving a main pass in order to get the denoise pass when using the commandline to render. Can't say "thank you" enough for it!
Posted: Thu Nov 08, 2018 11:49 am
by teeshiiddo
Thank you, great update.
Is the mix material auto convert putting the materials in the wrong order?
Scene attached:
- Mix.zip
- (125.75 KiB) Downloaded 260 times
Posted: Thu Nov 08, 2018 12:40 pm
by tomsvfx
Hi Aoktar!
Thanks for implementing that feature that allows to save each render pass seperatly from LiveViewer, but its not saving alpha channel, transparent images comes out with black background.
